Last edit by: IB Advertising
Browse all: Tires and Wheels Guide
- How to Fool Your Tire Pressure Sensors
Step by step instructions for do-it-yourself repairs
Tpms trick with spare tire?
im getting aftermarket wheels to run only spring-fall. If I can save close to $300 on tpms id like to. Whats the trick with tpms and keeping them on or near your spare tire in the trunk? Can someone explain how this is done? Do you just tape the sensors around the rim or something? im not sure how the sensors actually work. thanks
i see that but i was going to get my set up from tire rack and have them mounted and balanced. If i do that then id have to have a shop take the tire off and mount the ebay ones them remount and balance the tire. Dont want to go through all that. Tire rack is charging $78 for each sensor
You're trying to do what I did when I had wheels that didn't support TPMS. Take all your sensors and put them in your spare tire (no need to "mount" them, just deflate the tire & toss them in, reinflate). Works like a champ - it's the same principle as the "TPMS Pipe Bomb".
And in case you're wondering, I actually DID have to use my spare tire once will the TPMS still in them. Surprisingly, they survived the ordeal.
I also tried the pipe bomb DIY. That worked for a a while but the air kept leaking out somewhere, so i gave up.
What if u put all 4 sensors into the spare tires and pump it up to 35psi and keep it in ur trunk? Would that keep the tpms light off? Have anyone done this? I have the same issue I guess, cost for the new tpms then the bracket adapters, mounting, and balance again. That could be easily $300.
As an alternative to the spare tire & the TPMS pipe bomb, I recall one member shutting off the error light by zip-tying the sensors together.
Here's the link:
https://www.clublexus.com/forums/is-...-tie-tpms.html
Like I said in my earlier post, I successfully used my spare tire even with the TPMS sensors in it. It is not ideal and I don't recommend it, but it can be done.
Here's the link:
Here's the link:
also i keep seeing people writing about "programming" the sensors first. Do they have to be programmed in any way?
Keeping it Real
The sensors don't get programmed, the car gets programmed with the sensor's ID.
There is a reader to read the ID after the tires are mounted, or (preferably) you can write down the ID before getting them mounted. It then gets added to the car's computer as either the main or sub set.
Jeff
Jeff
Can any shop program the ID's in or do you have to get it done at a stealership?
Anything wrong with these? Others on ebay are selling for much more...
http://cgi.ebay.ca/Set-4-New-OEM-Lex...item43a495e6ce
just looking for a set for my winter tires on stock 17's 225/45 all around... thx
