corner light bulb swap
Old 02-08-11, 04:54 PM
Shibumi1
Shibumi1's Avatar
Default corner light bulb swap
does anyone know how to swap the corner (nike shaped) light bulb? does the whole housing have to come out?? thanks in advance..
Daybo (09-04-18)
Old 02-08-11, 05:17 PM
cmasten
cmasten's Avatar
Best I have been able to tell, you have to remove The bumper to get at it
Old 02-09-11, 12:37 PM
CJITTY
CJITTY's Avatar
i believe just bumper..there is another post on here about it and what it looked like after. It is a must do, looking forward to doing mine after seeing that pic the user posted Search for "Nike"
Old 02-09-11, 06:21 PM
Shibumi1
Shibumi1's Avatar
i did it without removing the whole bumper.. remove the grill (1) 10mm socket. the remove the plastic clips holding grille on each corner.then its easy as pulling the grille forward gently as u release the locking tabs (4).. once the grille is out you'll see a plastic trim w foam tucked behind the bumper trim on either side of the grille opening.bend it down then you'll see 2 wiring harnesses unclip them or bend the metal tabs holding them in place an you'll see the bulb socket reach in an turn it counterclockwise an pop the socket out.
The following 2 users liked this post by Shibumi1:
Daybo (09-04-18), PMD008 (03-02-17)
Old 02-09-11, 07:47 PM
CJITTY
CJITTY's Avatar
Oh, thats whats up right there!! Good job, I'll keep this as option 1 now!
Old 02-09-11, 08:45 PM
Shibumi1
Shibumi1's Avatar
bulb size is a 2825.. i put the 8smd led bulb in.the colors good but not quite bright enuff for me. so im goin to up it to 28smd led...
Old 02-09-11, 09:11 PM
CJITTY
CJITTY's Avatar
Doesn't the 2825 cross over to the 194/168 bulb style? Seems like the same setup. I know they have that PIAA bulb from Japan that the person did on here, and it seems super bright. Thats the goal, the brighter the light, the more of the "Nike light" shows through..i really want to do this, but been BSN just like fixing my wind noise...
Old 02-10-11, 04:10 AM
Shibumi1
Shibumi1's Avatar
yeah there w there a few crossover bulbs that worked.. but try to find something that has plenty of side view leds bcuz the bulb goes in at a right angle. so if u use a bulb like the 1 i got (which has 8 smd leds on a flat top surface) the light appears dimmer bcuz it has to reflect b4 being seen.
Old 02-10-11, 06:53 AM
cmasten
cmasten's Avatar
would a T10 (same as the 194/168) work with this kind of depth I wonder?
http://www.dealextreme.com/p/t10-1-9...r-dc-12v-51358
Old 02-10-11, 09:32 AM
Tdvlexo
Tdvlexo's Avatar
Yes, they will work. I have the same one on my car but not as bright as the piaa though.
diamente (07-04-18)
Old 02-11-11, 06:50 AM
sgmorton
sgmorton's Avatar
If anyone does this take pictures!!!!!!
Does anyone have a link for the PIAA bulbs?
Old 02-11-11, 07:43 AM
randomwalk
randomwalk's Avatar
Is the PIAA bulb leds are regular? I like to replace with LEDs if possible.
Also, if someone is doing this, please take a few pics as you remove stuffs to get to it would help greatly. Thanks.
Old 02-11-11, 05:54 PM
Shibumi1
Shibumi1's Avatar
when my new bulbs come in i'll take pics.. or if i have time tomorrow i'll pull it apart.. only takes a few mins now...
Old 02-11-11, 07:08 PM
cmasten
cmasten's Avatar
This is huge for those of us that will replace these thanks for the tip Shibumi1
Old 02-14-11, 05:32 PM
Shibumi1
Shibumi1's Avatar
np anytime.. i was really busy this weekend.. i'll try to post some pics this week..
Quick Reply: corner light bulb swap
