RX 330 seat memory does not work.
Everytime I set the seat to a position,and press set then 1.(The position should saved in 1)
Next time when I press 1, but the seat is not set to the position where I setted.
whyyyy
whyyyy
I have similiar issue with my 08 350. I have set both postions. However when I turn on the engine, sometimes potion 1 works and some times position 2 works. If one position work, it will work for a couple of weeks.
I haven't really start diagnosing this issue. I am going to disconnect the negative of the battery for about 10 minutes and reconnect it to see whether this can be fixed or not. If it can't be fixed I will bring my car to the dealer. Buy the way, I have bad experience with the dealer and I don't go there if not absolutely necessary.
^^ Disconnecting the battery is what 'removes' the settings...
This is the case in many LExus'. My ES300 does it, my dad's '04 RX was the same story when we removed the battery and put it back in.
I disconected battery today for 30 seconds. The driver memory position 2 still doesn't work. When I set the position I don't hear beep.
The positio1 works fine now. I wonder whether there is fuse only for position 2?
