Question about Apexi SAFC V1
I just picked up a SAFC V1 and wanted to know am I going to be able to tune fuel with this, how many of you are using the V1? I downloaded the manual and it didnt say anything about fuel adjustments. I want to make sure if I'll be OK with this or not before the install.
I see the V2 has fuel adjustments and settings.
v1 adjusts on injectors pulses by dialing in or dialing out.. The downside of the v1 is, it only has 12 points of corrections whereas the v2 has 24 points.. However, the v1 will do the job. Remember, it is for fine tuning but you can do some decent tweaking with it.
only adjust the High settings (your open loop setting) and add correction to your rpm range between 5500rpms and above. You want to run somewhat rich at those levels to prevent a catastrophe. The more the merrier IMO.
Do not adjust your low setting as that is your closed loop setting (idle) unless necessary.
Also, note your throttle settings are necessary
Is this for your 1.5jz??? the running rough problem??? If so what injectors are you using?? If its the stockies your going to have to add fuel with the controller at idle lo settings. You really should get a wideband before any fine tuning
What the function of a wideband? Is it like an O2 sensor where it just monitors the oxygen in the exhaust stream?
its like a o2 sensor, it tells you your air fuel ratio, it's a gauge that you use to fine tune your vehicle. Once it's installed you can adjust your fuel controller accordingly to numbers the Air fuel ratio says to get the best mixture.
wideband is just a very accurate o2 sensor. all a regular o2 sensor tells you is rich or lean, which is really not usefull for tuning, a wideband tells you exactly how much.
440cc should have gotten it pretty close to where the ecu can figure out the rest. you may have a different issue.
An AFC should work for what you want to do. yo would want to add the same number all across the board on the low map to compensate for injector size, so # of tuning points is not going to matter much for you.
on the high map you would have the same numbers (non boost rpm's) and the same or higher in boost rpm's depending on your AFR (wideband comes in handy for this), but the higher positive your correction is in boost the sooner you will hit boost fuel cut, so watch out for that.
consider running a 2jzgte ecu (I feel like a broken record). you already have most of the stuff you need, you just need a stock sc300 harness and add the ignition wires from your 1j harness, wire up map sensor and IAT (same for 1jz/2jz) and you wont have to worry about displacement issues anymore if thats really the problem.
The car hits Fuel cut at WOT. I was gonna get a FCD but IIRC I read running a SAFC is a better option cause I can tune it.
Im gonna wait on the wideband until I get the car running normal.
As for running a 2JZGTE ECU, maybe later down the line. This thing is giving my nothing but headaches and Id like to sort things out before I do any other mods.
11.5% CO2, which is Carbon Dioxide. 14.7% cO2 is Stioch so we want to get close to that as possible. My CO(carbon monoxide-fuel) levels are 00.0 and the O2 levels were around 3% which is high.
I tested this on a dynanometer to get these readings which puts a load on the vehicle.
BAD954BOI
SC400 / 300 Classifieds
10-04-12 02:35 PM
