IS300 Torsen LSD into IS250
Old 08-11-11, 09:47 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Default IS300 Torsen LSD into IS250
So I've been thinking about doing this for some time now, I had researched it before I bought my IS, and it all seems pretty straight forward; I don't know if anyone has done this swap before, but it shouldn't be too bad.
After calling around and looking for the last while, I finally managed to find a decent price on a 3.91:1 Torsen T-2 out of an Automatic IS300, so I ordered it yesterday and they dropped it off today. As Torsen's act like open diffs in almost all circumstances when testing them out of the car, I needed to open up the case to double check that it was in fact an LSD. I also wanted to check the gear pattern for wear and I wanted to make sure the diff looks "fresh" again on the outside of the case (throwing a used pumpkin into a brand new car and all that). I'm going to replace the 2 axle seals, pinion seal, drain and fill plugs, as well as the breather and then throw it into my IS250 next week sometime, provided all the parts I order come in soon. I want to replace the cover bolts and there aren't any around at the moment.
Basically the IS300 uses the same differential case/setup as the IS250 RWD and 09+ IS250 AWD. The 06-08 IS250 AWD uses a smaller diff and the IS350 uses a larger diff (same size as the IS F). I'll need to pull the axle stubs out of the diff as well, since the 2IS doesn't use them (the axles go right into the diff, and are splined, instead of bolt-on).
I am quite looking forward to how it feels going from the 3.73:1 Semi-LSD to the 3.91:1 Torsen. Should be a tad more peppy, I'd think, especially off the line.
More pics/info as I go along.
Jeff
Old 08-11-11, 10:06 PM
Hoovey689
Hoovey689's Avatar
cool mod!!!
Old 08-11-11, 10:29 PM
brociouz
brociouz's Avatar
It's so nice to have such a knowledgeable, mechanically-inclined person on this forum. Karma for you.
Old 08-11-11, 11:44 PM
kumquatism
kumquatism's Avatar
Can't wait to hear more about it!
Old 08-11-11, 11:55 PM
Sffd103
Fire Slayer
Sffd103's Avatar
Sounds awesomei
Old 08-12-11, 12:15 AM
GiantsFan
GiantsFan's Avatar
I'd like to know more about this!!
What does changing the gear ratio do?
Old 08-12-11, 12:37 AM
MrBBQ
MrBBQ's Avatar
So no go for us IS350 owners? The stock semi lsd feels weird, it's not very smooth at all.
Old 08-12-11, 12:51 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
01-05 IS300 models have a 205mm rear differential
06-08 IS250 AWD models have a 190mm rear differential (A Torsen from an IS200/RS200 Altezza might work well in this application)
06-11 IS250 RWD & 09-11 IS250 AWD models have a 205mm rear differential (The IS300 Torsen should be a bolt-in upgrade for this application)
06-11 IS350 and IS F models have a 208mm rear differential
So no, this won't work for an IS350, you may be able to use a 2010-11 IS F Torsen LSD, but you wouldn't want to use the complete IS F pumpkin, as the IS F has a 2.9'ish final drive, which wouldn't be a good match to the IS350's transmission gearing. (IS350 has a 4.08:1 final drive). I don't know if anyone has tried to put the IS F Torsen into an IS350 differential though, so I don't know much about that.
Jeff
Old 08-12-11, 01:08 AM
cookies
cookies's Avatar
can't wait hear about this good luck
Old 08-12-11, 01:19 AM
Sango
Sango's Avatar
You can use OS-Giken for the 350. Direct OE replacement.
http://www.dezod.com/pd-os-giken-limited.cfm
I will be getting 250 versions of it as well for my 250.
http://www.dezod.com/pd-os-giken.cfm
Old 08-12-11, 05:26 AM
B16da9
B16da9's Avatar
Great project, I would be very interested in doing this to my car depending on your results.
Old 08-12-11, 08:10 AM
iRock
iRock's Avatar
Nice someone should try to pit the IS-F part in the 350 . I would be interested
Old 08-12-11, 10:10 AM
c-low
c-low's Avatar
uh o mad scientist
Old 08-12-11, 10:24 AM
Gville350
Gville350's Avatar
Personal perference, I prefer the mechanical/helical gears of a Quaife LSD :
http://www.autotech.com/product/oem-...arts-clearance
No clutch disks to worry about. Here's the one I installed into my Civic trans :
Jeff, have you or others done the measurements to see if a 350 final drive ring gear would at all fit on a 250 diff/300 Torsen LSD?
Old 08-12-11, 10:49 AM
evogt500
evogt500's Avatar
So let me get this straight, the older is300 has a real lsd and the is250 only has a semi LSD? Do you know what exactly is a semi-LSD and how is different from a torsion LSD? Its one of those mysteries on the Lexus brochure that no one really talks about. The Semi LSD and the 2-piston brake calipers on the IS250 (I only see one piston).
Quick Reply: IS300 Torsen LSD into IS250
