Anyones dash rattling and popping really loud???
Old 12-07-10, 11:29 PM
zoli21
zoli21's Avatar
Default Anyones dash rattling and popping really loud???
I bought this car three months ago and the dash is driving me nuts, it creeks and pops really loudly over uneven surfaces, does anybody have this problem, and how can it be resolved thxx
Old 12-08-10, 12:51 AM
Frosty250
Frosty250's Avatar
Yep, mine does that too. Take it to your dealer.
Old 12-08-10, 07:09 AM
pepos
pepos's Avatar
It's a common ISx50 issue and LEXUS dealers fix this under warranty.
There is a TSB for that in Lexus knowledge database.
Bad thing is that they have to dismantle the dashboard to fix it.
File Type: pdf
Old 12-08-10, 07:31 AM
JMcDonald
JMcDonald's Avatar
Yea bad part about them fixing it is after they fix it.....it will keep coming back, there is a member who solved the issue and did a write up on here.
Old 12-08-10, 08:23 AM
ChrISF
ChrISF's Avatar
can you find the link?
Old 12-08-10, 08:37 AM
meangene
meangene's Avatar
I get the nasty pop more than the rattling
Old 12-08-10, 09:26 AM
pepos
pepos's Avatar
Pop comes from the instrument cluster.
It's an easy fix.
Old 12-08-10, 09:41 AM
BinaryJay
BinaryJay's Avatar
Jamming a few pieces of black eraser in between the windshield and the dash goes a long way into tightening it up so it doesn't move and cause the clips to make noise. It's cheap and easy, seems to work and it keeps your dash in one piece.
Old 12-08-10, 09:50 AM
funglenn
funglenn's Avatar
can someone explain where--mine only makes noise below 50 degrees!
Old 12-08-10, 09:59 AM
localhost
localhost's Avatar
Sent mine back to dealer about a month back and they fixed it by installing a new part (rubber clips) to hold the dash. Didn't hear anymore rattle thereafter. Might want to check with your dealer.
Old 12-08-10, 10:18 AM
meangene
meangene's Avatar
It's an easy fix.
I'm going to have to pay more attention to it. I thought it was coming from somewhere else
Old 12-08-10, 10:32 AM
JMcDonald
JMcDonald's Avatar
The main cause is from behind the dual vents in the center, its a clip that holds them together causing the popping. Its caused by the heat/cold expansion of the plastic.
Old 12-08-10, 10:35 AM
funglenn
funglenn's Avatar
I know mine is not there, i hear the same click/pops even when i have the whole vent section removed. It seems to be from off to 6 inches to the passenger side from center.
Where are the dash clips located that someone mentioned? these noises are no where near as bad as the squeaks on my 4runner were--those ended up being the metal bar that does across the dash for support!
Old 12-08-10, 10:41 AM
pepos
pepos's Avatar
Just look the TSB pdf in the beggining.
You will see the location of the clips.
If the car is still under warranty everything can be fixed by Lexus dealer free of charge with the new parts Lexus has produced.
There is also a new rubber seal that goes to the the middle of the dash on the top of heat exchanger.
Cars made after 2008 don't have these problems because Lexus upgraded the quality of the clips (Rubber ones).
Old 12-08-10, 10:48 AM
funglenn
funglenn's Avatar
I cannot get to the PDF, it will not open--just sits there until it times out. However mine is no longer under warranty, so pulling out hte dash (if that is what it takes) is a bit too much--I will go the erase route or something else if it is cheaper/easier/quicker.
Quick Reply: Anyones dash rattling and popping really loud???
