LS Brakes
LS Brakes
Question about the LS brakes. I noticed alot of people here upgrade/change to the LS brakes, why? Isn't there aftermarket brakes for SC's available, like Wilwood? I'm looking to upgrade my brakes and I'm just wondering what's the best route to go.
Have you priced Big Brake Kits? You can do the the LS swap for around $300 depending on where you get the calipers from and what rotors you go with. An aftermarket BBK will set you back over a grand.
^hah maybe an 8 piston brembo...
anyway you can get a full 13" 4 piston wilwood setup for the front for around $1200 including all hardware. And yes, that wilwood caliper is significantly stronger than the TT caliper (tested personally). However, for what MOST people need the LS400 setup is perfect and the extra $800+ for something bigger/stronger isn't worth it for a daily driven cruiser.
tiguy99 (03-22-17)
Yeah the LS400 setup is by far the best bang for the buck especially for the daily driver,but if you've got the money and your going for wow and style points or you're actually going to need superman stopping power, then by all means spend! spend! spend! This is what I did to mine and i'm happy with the outcome.
Before:
And after:
Just my 2penny's worth.
Before:
And after:
Before:
And after:
Before:
And after:
So basically it's more of the pricing that's why alot of you guys go for the LS brakes... Good to know, it is really gonna cost about a grand for the Wilwood I've already checked for the whole set! Thanks for the input guys!
Bigger rotors:
You want to loosen a tough bolt. Try it with an 8" wrench and it's not working. Now swap that 8" for a 16" and watch it break with ease. This is the effect of a larger rotors- you have more torque on the wheel by increasing the radius of the force applied on the rotor
Larger calipers:
Now that that same 16" wrench. Take your index finger and push down as hard as you can on it- now try it with your whole hand. The larger surface area of your hand combined with the greater force will increase the torque on the bolt just in the same way a large caliper holding larger pistons with a great piston contact area and a higher fluid mass will increase the clamping force on the rotor. Of course just as you are limited to the strength of your arm, you are limited by the size of your master cylinder, but the increase in pistons contact area will absolutely make a difference
I've seen your thread about this and btw I love it so much that I'm jackin' your style once I decide what breaks to go with(although I'm doing the body color of my SC instead of black but still with the Lexus decal)
Here's a good way to related it.
Bigger rotors:
Larger calipers:
Bigger rotors:
Larger calipers:
