Staggered setup on AWD ! - The Mother Thread - !
I want to open this thread where PEOPLE WHO ARE ACTUALLY RUNNING THIS SETUP (Staggered on your IS250awd) post here -
Please post on these topics:
- What is your exact wheel/tire setup ?
- How many miles you've been running this for ?
- Are you noticing any issues (gas millage ect...)
- Also post your general thoughts/comments
Again, people who are actually running this setup - or - people that are well educated on the topic - please post here so we can have a dedicated thread for this highly debated topic.
volk gt av 19 x 8.5 n 9.5
tires dunlop sport maxx 225/35 n 235/35
off set 24 n 25 i be;ieve
10k plus miles
havent noticed any gas problem i guess when modding cars i dont pay attention to that stuff that closely anymore
ride qaulity is decent which i expect im cambered a little cause of the drop n offsets
none the less you look gangsta as **** if u keep your ride clean and cruising, i have them with kics r40 and ppl are just liek wtf
![](http://c2.ac-images.myspacecdn.com/images02/27/l_9c16a4680c8845b5b775c615f95d1a55.jpg)
ill be running 19 x 9 n 10 with a 22 offset soon as im done being lazy and get them on
10k plus miles
MRR HR2's
19x8.5 +35 up front with 235/35/19 exclaim UHP's
19x9.5 +39 in rear with 275/30/19 exclaim UHP's
rolling diameter is .1% difference which is virtually nothing
had the tires on since March. approximately 15,000 miles on them so far.
no issues what so ever concerning the awd system.
gas mileage is about the same, averaging currently with my commute about 24mpg 50/50 mix.
dropped on F-sports. front has a very minor rub and is pretty close to flush, and the rear is slightly tucked behind the fender by less then a finger.
2IS OG
10k plus miles
10k plus miles
Javier
![](http://farm4.static.flickr.com/3438/3912866534_157ef5a24e_o.jpg)
F - 19x8.5 Face-1 35mm offset. Toyo Proxes T1-R 235/35/19
R - 19x9.5 Face-2 36mm offset. Toyo Proxes T1-R 265/30/19
Dropped on Eibach springs for IS350
10,000 miles
No problem so far... gas mileage is about the same
The wheels diameter is less than 1% difference so I don't think there would be any problem
like any setup it all depends on the personal users wants/setup
like fo r me i want wide and low off set and (future drop will be tucked i hope) low
so in doing so stretched tires come into play negativr camber shaved/rolled fenders
First off. Wonderful forum and it's full of very knowledgeable people.
Alright... so major question here to the users that are running this setup. I placed an order for staggered rims last night and I'm really hoping this will work.
Car: 06 IS250 AWD
Wheel Make & Model: TSW Snetterton
Wheel Size (diameter and width): 20x8.5 & 20x10
Wheel Offset Front: ? <-- Not sure. Whatever the default is.
Wheel Offset Rear: ?
Tire Front: 235/30ZR20 Kumho Ecsta SPT
Tire Rear: 275/30ZR20 Kumho Ecsta SPT
Suspension mods: H&R springs for the AWD 250
After some research after I placed the tire order from TireRack. I'm seeing that I'd have to drop the rear profile slightly to get the correct ratio. However, it's impossible to find lower profile then a 30 with reasonably priced tires. So obviously need to cancel this order and get the correct profile tires. Would a 35 instead of a 30 fit in the front without rubbing?
Really need some help ....
If this is the wrong thread to discuss this... my apologies.
Quick Edit:
Looks like a 35 in the front and a 30 in the rear would be the perfect ratio. However... how bad would the rubbing be in the front on a 20 x 8.5 rim and 235/35/20 tires with the H&R drop?
Tire 1 - 235/35R20 >Search Tires Tire 2 - 275/30R20 >Search Tires
Section Width: - -
Section Width: 9.25 in 235 mm
Section Width: 10.82 in 275 mm
Rim Diameter: - -
Rim Diameter: 20 in 508 mm
Rim Width Range:
Rim Width Range: Unrecognized tire size.
Rim Width Range: 9.5 - 11 in
Overall Diameter: - -
Overall Diameter: 26.47 in 672.33 mm
Overall Diameter: 26.49 in 672.84 mm
Sidewall Height: - -
Sidewall Height: 3.23 in 82.042 mm
Sidewall Height: 3.24 in 82.296 mm
Radius: - -
Radius: 13.23 in 336.04 mm
Radius: 13.24 in 336.29 mm
Circumference: - -
Circumference: 83.15 in 2112.0 mm
Circumference: 83.22 in 2113.7 mm
Revs per Mile: -
Revs per Mile: 785.7
Revs per Mile: 785.2
Car: 06 IS250 AWD
Quick Edit:
Section Width: - -
Rim Diameter: - -
Rim Width Range:
Radius: - -
Circumference: - -
Revs per Mile: -
10,000 miles
Car: 06 IS250 AWD
Quick Edit:
Section Width: - -
Rim Diameter: - -
Rim Width Range:
Radius: - -
Circumference: - -
Revs per Mile: -
Car: 06 IS250 AWD
Quick Edit:
Section Width: - -
Rim Diameter: - -
Rim Width Range:
Radius: - -
Circumference: - -
Revs per Mile: -
