Official ES HALL of FAME links thread (Newbies and O.Gs come inside)
Guest
Posts: n/a
![Arrow](https://www.clublexus.com/forums/images/icons/icon2.gif)
Okay I've done this in a couple other forums, its to have less first page clutter. All the stickies are now here. If you want anything added, please post it up. Thanks
Mike
ES 02-05 Transmission Fix
https://www.clublexus.com/forums/es3...ssion-fix.html
2ES Project Thread: Custom LED Lighting
https://www.clublexus.com/forums/es3...-lighting.html
ES 300/Windom hot pics!!!
https://www.clublexus.com/forums/es3...-hot-pics.html
Official ES Aftermarket/OEM Wheels Thread
https://www.clublexus.com/forums/es3...ls-thread.html
2ES (92-96) ES300 Suspension Reference
https://www.clublexus.com/forums/es3...reference.html
ES330/300 DIY (do-it-yourself) & technical tips
https://www.clublexus.com/forums/es3...ical-tips.html
ES Aero parts fitment FAQ
https://www.clublexus.com/forums/es3...tment-faq.html
Low Budget DIY Solution for Burnt Out Needles
https://www.clublexus.com/forums/es3...t-needles.html
The Best & Only Intake That Works. $25-40usd
https://www.clublexus.com/forums/es3...-25-40usd.html
The Free Mod Series - Part I Quicker Transmission Shifting
https://www.clublexus.com/forums/es3...-shifting.html
Tire size calculator
http://www.1010tires.com/TireSizeCal...?action=submit
Wheel/offset calculator
http://www.bigcustomwheels.com/info_specs.jsp
http://www.1010tires.com/WheelOffsetCalculator.asp
How to add LEDs interior lights to your 3ES
https://www.clublexus.com/forums/es3...h-of-leds.html
Clear 2ES headlights
https://www.clublexus.com/forums/lig...r-corners.html
Hello everyone. My first Lexus is a 1992 ES 300 manual, still going strong! This forum has many different ES models in it, so to make it easier for people, please do one of the following in your title
1. Put the year ES you are talking about (example; 1997, 2002, etc)
OR
2. Use the generation designation I came up with
-1ES=ES 250
-2ES=1992-1996 model
-3ES=1997-2001 model
-4ES=2002-2006 model
-5ES-2007- model....(has own forum)
Thanks!!!
Mike
OR
-1ES=ES 250
Thanks!!!
Mike
Mike
Regional Officer - NTL
Simple instructions on how to clear 2ES headlights: https://www.clublexus.com/forums/lig...r-corners.html
https://www.clublexus.com/forums/lig...t-to-know.html
1997-2001 HID conversion. Only thing missing in that thread is the H7 bulb adapter. You can re-use the old one but drill it out so it sits nicer, or you can ghetter fab the brackets to hold the bulb in.
Another option is to BUY an H7 adapter, where its ready made for you to drop in.
And a nice Projector conversion thread by an old ES300 owner on here: https://www.clublexus.com/forums/es3...o-mini-h1.html
Okay. Mods need to add/update/delete some old threads no longer active in the OP.
Here's what you need to add;
Adding OE chrome to your 3es;
https://www.clublexus.com/forums/es3...-up-a-bit.html
Fix radio bulbs in 3ES Pioneer;
https://www.clublexus.com/forums/es3...s-pioneer.html
3ES suspension build thread with part numbers;
https://www.clublexus.com/forums/es3...aul-guide.html
3ES [99-01] adding auto windows with FOB;
https://www.clublexus.com/forums/es3...ndows-mod.html
3ES adding 'MIST' feature to the car;
https://www.clublexus.com/forums/es3...d-no-more.html
3ES one potential solution to front end noise;
https://www.clublexus.com/forums/es3...se-solved.html
3ES; OEM HID 'retrofit' discussion/pics;
https://www.clublexus.com/forums/es3...-oem-hids.html
3ES Power folding JDM mirrors;
https://www.clublexus.com/forums/es3...g-odyssey.html
3ES, MISC sport discussion suspension/tires;
3ES rear hub/trailing arm bushing replacement DIY;
https://www.clublexus.com/forums/es3...ngs-fixed.html
