Need complete change of headlights on my 08' IS350!
Hey guys!
So, basically, I am pretty much tired of my headlights on my 2008 IS350... I just dont like any lights that arent "White and bright". Right now my driver lights (the lights that are always on no matter what, and you cant turn them off!) are annoying me the most, they are literally orange, as most of you know. As well as the high beams.
Anyway, in short, I would like for all of my lights to all be white and not orange, and relatively bright (not too bright) xenon.
Now, I have 0 knowledge when it comes to lighting/electrical - so could you guys please tell me what I need to buy to make the changes I want to my car? A link to a place or ebay or maybe sewell lexus that I can order it from would be great!
I have seen the 6k HID's etc etc... but again, I know nothing about lighting, and dont know what to get exactly... so please give me some input guys!
Many thanks in advance!
Hey guys!
6K hid are White 8K HID BLUE i would pick 6kHID BLUE is too BLUE
just follow this link to change it
https://www.clublexus.com/forums/is-...hid-bulbs.html
Your IS350 comes with HID as stock, just change the bulb. the size is D4S
Thanks!
Hey guys!
1) Turn them off. You can go to a Lexus dealer and ask them to simply turn off your DRLs. That way they won't be on all the time and your high beams will still work when you want them. It's simply a setting the dealer will switch, there's nothing else involved other than hooking up a computer and clicking a few times. Some dealers will do it, others will balk. Not sure why this is, but that's the experience I've seen CL members have.
2) Replace them with different bulbs. Some people try and make the lights look less orange by replacing the bulbs with "whiter" bulbs. Unfortunately, as I understand from reading other threads on this, basically any bulb at half power will still look pretty orange. So this won't really solve your problem.
3) Replace them with LEDs. This will actually turn your DRLs to whatever color you want. Search CL for "LED DRLs" and you'll find tons of pics, how-tos, links, etc. But the thing to remember with this is that replacing your DRLs with LEDs will eliminate high-beam functionality. That means you won't have high beams or "brights". In addition to being an inconvenience, this might also be illegal in some states/areas.
Here's an explanation of the lights on the front of the car:
1) Low beam (halogen or HID)
2) Parking light (smaller halogen bulb)
3) DRL/high beam (halogen)
4) Fog light (halogen)
What other lights are you trying to change? Also, do you have HID low beams or halogens? You may not know, in which case someone else is going to have to chime in on how you figure that out, I just know from looking.
Calvin: Thanks a lot for the input, you basically told me almost everything I need to know! I WISH I knew I could go to the dealer and have them disable the DRL, I am sure they would do it for me, I know them there and they are all nice.
BTW - for my normal beams, shouldnt they be HID? arent they all HID on a 2008 IS350? The color on those are white, and I am not complaining on those. However, I might change them to the 6000k since I found out it would be really cheap to do it!
Anyway, after seeing Jzsicklexi's pics of the LED DRL's, I have got to look into getting those! But Im really gonna have to think about the no high beam disadvantage, I use them quite a bit, on many occasions I use them to warn other cars as well instead of using the horn.
The most Ideal thing for me would be to have the 2011/12 lights on the ISx50's!! I LOVE the LED's! but unfortunately, their price is outrageous!
How to tell? If you have memory seats you have HIDs. If you don't then scroll through the menu options with the multi-switch (the switch to the lower left of the steering wheel that looks like <0>) and if you see an option for AFS ON/OFF you have HIDs.
Yup, price is nuts... plus if you did have HIDs previously you lose AFS.
Yeah I have retrofitted Tsx projectors and 55w bulbs and ballast and with my high beams on it seriously isn't puttin any more light on the road with my setup. That's the only reason I got the LED DRLs.
This is with just my low beams on...
This is what I did.
1. Get dealer to turn off DRLs
2. Swap in new city lights from V-LEDS
3. Get HID fogs installed
4. Swap out stock HID bulb for a higher color temp (optional).
My high beams work (the light is yellow but I never use high beams anyways). I don't have DRL anymore but I don't miss them.
1stGenIS
03-11-14 11:17 PM
Rock-a-Lex
02-28-10 11:42 AM
