DIY IS-F Spark plug change
Old 06-03-12, 01:20 PM
newguy1354
newguy1354's Avatar
Default Help. I need the IS-F Spark Plug torque spec!
I am doing the 60K service and will be posting a write up with photos. I have searched high and low for the spark plug spec and found nothing.
Anyone have a reference for it?
Thanks
Old 06-03-12, 01:29 PM
SeanGTS
SeanGTS's Avatar
Typically you go by feel, put them in snug. They dont need to be super tight.
staman
staman's Avatar
21 Nm (214 kgf-cm,15ft-lbf)
Old 06-03-12, 01:30 PM
staman
staman's Avatar
16mm plug wrench..
Old 06-03-12, 02:29 PM
MRxSLAYx
MRxSLAYx's Avatar
x2 Just did mine again and I always go by feel. Job takes less than an hour is you know what your doing and your hands are skinny ...
Old 06-03-12, 07:24 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,076 Likes on 2,470 Posts
Bad idea to go by feel. If you overtighten them, the shell distorts and the heat range is impacted usually negatively. Torque to spec and you'll have no issues. Go by hand and expect they'll all be a little different.
I bet you wouldn't fly on an airplane where the mechanics installed engine parts by hand instead of following the torque specs in the manual...I know I wouldn't knowingly do this.
Old 06-03-12, 08:05 PM
SeanGTS
SeanGTS's Avatar
Then I would propose you don't have a good feel
Old 06-03-12, 08:10 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Not exactly. I have four torque wrenches and lots of experience working on aircraft I had to fly on myself.
Old 06-03-12, 08:14 PM
SeanGTS
SeanGTS's Avatar
Meh, I'm 27 years old, I know it all.
No but really, how often do you verify the accuracy of your torque wrenches? What brand are they? I've read so much information about inaccuracies of torque wrenches (particularly when not taken care of and properly maintained). Always taken mine to be more about precision, rather than accuracy.
Old 06-03-12, 08:30 PM
RichieISF
RichieISF's Avatar
So is 21 Nm the correct tension?
Old 06-04-12, 02:38 PM
staman
staman's Avatar
Yup. That's straight from TIS....
Old 06-04-12, 04:18 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Three Snap-On. Yes, precision over accuracy, but if you're good to them, they hold calibration well. I also have a Sears microtork I bought in the early 80's. It consistently tests within 3in-lbs of indication from 20 ft-lbs to 80-ft-lbs.
A lot of the reason for inaccuracies is in where you grab the wrench. As bizarre as it sounds, the location of your hand impacts the accuracy of the pull. I didn't believe it myself until I saw it demonstrated.
Back to the sparkplugs - if they're all consistently overtightened, they'll all have the same problem. If you do it by hand, you could have one cylinder cooking the plug and everything else fine. You'll be tearing your hair out to try and figure out why. I'll pass on that by making sure they're all the same even if my absolute value is a little off.
Old 06-04-12, 08:50 PM
GSteg
GSteg's Avatar
I always torque spark plugs using a torque wrench. Under-torqued plugs will do SERIOUS damage to your engine once they've loosened themselves. I have a friend who hand tightened his plugs on his GS400. One of them became loose after 50 miles, and caused major damage to the valves and piston. Mind you, he's done spark plug changes before so it's not his first time.
Old 06-04-12, 08:53 PM
GSteg
GSteg's Avatar
Isn't that always the case for everything else?
I have a decent amount of torque wrenches, but I never beat on them. They're precision instruments, and I treat them as such.
Old 06-04-12, 09:04 PM
SeanGTS
SeanGTS's Avatar
Shoot son, I guess were not working on lawn mowers and weed eaters anymore here folks.
BTW: Spark plugs at 60k? Didn't think that was required.
Quick Reply: DIY IS-F Spark plug change
