Lights not turning off
Old 11-12-12, 07:12 AM
USCRugby
USCRugby's Avatar
Default Lights not turning off
I have an 08 LS460 and set my lights to auto.
I have noticed recently, two times I have turned the car off and the lights stay on.
One time was in the garage and I never lock the doors while parking it in my garage.
They were on for 15 mins after I turned off the car.
Suggestions?
Old 11-12-12, 01:36 PM
jamodeo
jamodeo's Avatar
Your door sensor may be sticking. When you shut off the car, and the light switch is in auto mode, it must sense that the drivers door has been opened and then closed to start the automatic off timer. Make sure when you are exiting the vehicle, that the dome light comes on and the info display says that a door has been opened.
-Joe
Old 11-12-12, 02:26 PM
CJITTY
CJITTY's Avatar
This has been discussed at length..use of the search feature would of led you here https://www.clublexus.com/forums/ls4...rning-off.html
Old 11-13-12, 10:44 AM
jamodeo
jamodeo's Avatar
Sorry, figured I would try and answer it since I thought I could help. I come to the LS section every once in a while because there isn't much chatter regarding the 460 motor/8speed in the 3GS section. I know its not the exact same thing, but some threads roughly translate over into my car and all of you are very helpful (I do find most of my answers using the search).
So I guess, hello all!
-Joe
Old 11-13-12, 08:02 PM
FLYCT
FLYCT's Avatar
Suggestions?
Check out this thread I started. I included a few videos of how I identified my problem.
https://www.clublexus.com/forums/ls4...-wont-set.html
The curtesy light switch on the driver door was Intermitant. The passenger side was also Intermitant but not as bad. Both were replaced and now my lights turn off every time in auto mode.
JR
Old 11-14-12, 06:53 AM
jmcraney
jmcraney's Avatar
If you are experiencing, or have experenced in the past, a problem with your lights not going off that is related to the door switch, please enter a complaint at the NHTSA site: http://www.safercar.gov/
To enter a complaint, click on "Vehicle Owners" in the selection bar at the top and then select "File a Complaint" along the left side. The defective switch impacts several of the car's safety features and your report may save someones life.
Old 11-14-12, 10:52 AM
ehaze
ehaze's Avatar
swap the drive and rear door switches.
if the problem is solved, order a new switch and replace the broken one.
total time: 10 minutes
cost: ~$22
tommytqt
NX - 1st Gen (2015-2021)
15
09-24-21 05:20 AM
Copguy
ES - 5th Gen (2007-2012)
03-30-11 07:08 AM
Pnuge88
03-22-07 03:47 PM
Quick Reply: Lights not turning off
