Last edit by: IB Advertising
Browse all: Tires and Wheels Guide
- Tires General Information and Specs
Important information to help you understand your Lexus
LS 460/600 Wheel & Tire Information Details Thread
ATTENTION. ON DEC 19, 2020, I CLEANED UP THIS THREAD BY DELETING MULTIPLE POSTS FOR REASONS EXPLAINED BELOW IN THE ORIGINAL POST. I HOPE THIS MAKES VIEWING THIS THREAD EASIER. PLEASE ALSO USE THE SEARCH FEATURE TO TRY AND NARROW DOWN WHAT YOU ARE LOOKING FOR WITHIN THE THREAD. THANK YOU
ORIGINAL POST FROM 11-22-2011:
The purpose of this informational thread is to be a one stop shop for all LS owners interested in wheel/tire information as it relates to the LS460 and LS600 models. There are plenty of threads to search through, but this will help make things very easy.
Please copy and paste the template below and input your details on your current setup along with two or three pics. I know this may take some time, but your input can really help folks out!
Lets try to keep this thread clean and streamlined as much as possible by only posting new posts with the template and answers. If you have additional questions that are not answered within the user's post, please PM them directly, or if they have a link contained within their signature block, please use that. Posts in this thread not following the template provided on this post will be deleted to in order to keep this thread as uniform as possible.
This is designed to help fellow forum users learn more about all the different setups available out there..what works well, what required additional work, what to keep in mind when getting ready to buy wheels etc.
Perhaps the mods can make this thread a sticky to make this info even easier for folks to find.
Please Copy and Paste this template into a new reply post (not Quote) and complete for your vehicle
______________________________________________________________
LS Year/Model:
AWD or RWD:
Wheel Brand:
Wheel Model:
Wheel Size Front:
Wheel Size Rear:
Wheel Finish:
Lip size front (if applicable):
Lip size rear (if applicable):
Lip finish (if applicable):
Offset Front:
Offset Rear:
Hub Bore size (if known):
Hub Centric Rings Required? Y/N:
Tire Size Front:
Tire Size Rear:
Tire Make/Model:
Tire Air Pressure Preference:
Suspension:
Fenders Rolled/Altered:
Does the setup rub?:
Pics Below:
LS Year/Model:
AWD or RWD:
Wheel Brand:
Wheel Model:
Wheel Size Front:
Wheel Size Rear:
Wheel Finish:
Offset Front:
Offset Rear:
Tire Size Front:
Tire Size Rear:
Tire Make/Model:
Suspension:
Pics Below:
Last edited by CJITTY; 12-18-20 at 11:41 PM. Reason: make template easier for copy and paste into new thread
LS Year/Model: 2007 LS460 SWB
Wheel Brand: Lumarai (TSW brand specifically for Lexus)
Wheel Model: Morro
Wheel Size Front: 20x8.5
Wheel Size Rear: 20x10
Wheel Finish: Silver with machine mirror face
Lip size front (if applicable): 1.75"
Lip size rear (if applicable): 2.75"
Lip finish (if applicable): highly machined polished
Offset Front: 31mm
Offset Rear: 31mm
Hub Bore size (if known): 60.1mm
Hub Centric Rings Required? Y/N: NO, OEM hub bore size
Tire Size Front: 245/40/20
Tire Size Rear: 275/35/20
Tire Make/Model: Continental Extreme DWS
Tire Air Pressure Preference: 35 psi all around
Suspension: Tanabe NF210 Coil Springs
Fenders Rolled/Altered: NO
Does the setup rub?: Slightly only with 3 adult (200lb+) passengers in rear. It rubs on rear grayish soundproof material only located just above rear fender lip edge. It only rubs now since car is lowered, it didn't rub while on OEM springs.
Pics Below:
DROPPED
DROPPED
NO DROP
Wheel Model: Morro
Offset Front: 31mm
Offset Rear: 31mm
Pics Below:
DROPPED
DROPPED
NO DROP
PAPICHULO (04-26-24)
LS Year/Model: 2007 LS460 LWB
Wheel Brand: Rennen International
Wheel Model: Donz Gotti
Wheel Size Front: 22x9
Wheel Size Rear: 22x10.5
Wheel Finish: Brushed/polished windows
Lip finish (if applicable): Chrome
Offset Front:
Offset Rear:
Tire Size Front: 245/30/22
Tire Size Rear: 295/25/22
Tire Make/Model: Falken FK452
Tire Air Pressure Preference: 41 psi all around
Suspension: Datasystem. I ride 50/50, super low/super low w/height high engaged (the most compliant setting).
Fenders Rolled/Altered: Shaved Rears
Does the setup rub?: No
Offset Front:
Offset Rear:
LS Year/Model: 2008 LS600hL
Wheel Brand: Rinspeed (made by Borbet)
Wheel Model: C5/1
Wheel Size Front: 22x10
Wheel Finish: Gloss black
Lip size front (if applicable): N/A
Lip size rear (if applicable): N/A
Lip finish (if applicable): N/A
Offset Front: +40
Offset Rear: +40
Hub Bore size (if known): 72.56 (wheels were made for Range Rover)
Hub Centric Rings Required? Y/N: Y
Tire Size Front: 255/30/22
Tire Size Rear: 255/30/22
Tire Make/Model: Hankook V4
Tire Air Pressure Preference: 40psi
Suspension: Data Systems controller on setting 6
Notes: Required Range Rover OEM lug nuts -- wheels were not drilled for aftermarket lug nuts.
Pics Below:
Wheel Model: C5/1
Offset Front: +40
Offset Rear: +40
Pics Below:
Wheel Brand: VOSSEN
Wheel Model: VVS082
Wheel Size Front: 22x9.0
Wheel Size Rear:22x10.5
Wheel Finish: silver
Offset Front:?
Offset Rear:?
Hub Centric Rings Required? Y/N:Y
Tire Make/Model:Pirelli P Zero Nero
Tire Air Pressure Preference:42
Suspension:stock for now
Fenders Rolled/Altered:no
Does the setup rub?:a tiny but only on the rear right and only since I used the Pirellis. No rubbing with the Continental DWS
Pics Below:
Wheel Brand: VOSSEN
Wheel Model: VVS082
Offset Front:?
Offset Rear:?
Pics Below:
LS Year/Model: 2008 LS460L Executive
Wheel Brand: Weds
Wheel Model: Kranze Bazreia
Wheel Size Front: 22x9.5
Wheel Finish: Super Chrome
Offset Front: +22
Offset Rear: +26
Tire Size Front: 265/30/22
Suspension: Data Systems/Skipper Lowering Links - Controller on Setting: 0
Fenders Rolled/Altered: Rears Rolled/Shaved
Does the setup rub?: Depends how low I decide to roll around that day
Wheel Brand: Weds
Offset Front: +22
Offset Rear: +26
LS Year/Model: 2007 LWB
Wheel Brand: Vossen
Wheel Model: CV1
Lip size front (if applicable): none
Lip size rear (if applicable): none
Lip finish (if applicable): Stainless steel
Offset Front:
Offset Rear:
Hub Centric Rings Required? Y/N: No
Tire Size Rear: 295/30/22
Tire Make/Model: Atturo
Tire Air Pressure Preference: 45
Fenders Rolled/Altered: Rolled
Went with 295/30/22 rears because the rear INVOs seemed to have a lower profile than the front and it didnt look right. Also have a slightly better ride since its more tire. The local tire shop basically gave me the tires to try anyways since the INVOs wore down at 13K miles. A little more road noise but ML more than makes up for it.
Pics Below:
Wheel Brand: Vossen
Wheel Model: CV1
Offset Front:
Offset Rear:
Pics Below:
Am i the only one with 21' ??
LS Year/Model: 08/LS460
Wheel Brand:AUTO COUTURE
Wheel Model:transform5
Wheel Size Front:21X9
Wheel Size Rear:21X10.5
Wheel Finish:BLACK ACCENT & LIP WITH SLIVER FACE
Lip finish (if applicable):BLACK
Offset Front:32
Offset Rear:36
Hub Bore size (if known):60.1
Hub Centric Rings Required? Y/N:N
Tire Size Front:245/35/21
Tire Size Rear:285/30/21
Tire Make/Model:Continental extreme contact DW
Suspension:OEM
Does the setup rub?:no
Pics Below:
Offset Front:32
Offset Rear:36
Suspension:OEM
Pics Below:
LS Year/Model: 2007 LS460L
Wheel Brand: Trafficstar
Wheel Model: RTV
Wheel Finish: Silver polished
Lip size front (if applicable): ~1.5"
Lip size rear (if applicable): ~3"
Lip finish (if applicable): Anodized
Offset Front: ~29mm
Offset Rear: ~29mm
Hub Bore size (if known): 73mm
Hub Centric Rings Required? Y/N: YES
Tire Make/Model: Falken 452
Tire Air Pressure Preference: 40 psi all around
Suspension: Factory air suspension with lowering module
Fenders Rolled/Altered: Rear fenders completely shaved. Front fender plastic trims removed, fenders rolled
Does the setup rub?: No rubbing unless hitting very bad dips.
Pics Below:
Wheel Model: RTV
Offset Front: ~29mm
Offset Rear: ~29mm
Pics Below:
LS Year/Model: 2008 LS460 SWB
Wheel Brand: Lumarai (TSW brand specifically designed and manufactured for Lexus)
Wheel Model: Morro
Lip finish (if applicable): Highly machined polished
Offset Front: 31mm
Offset Rear: 31mm
Hub Centric Rings Required? Y/N: No. OEM hub bore size
Suspension: Factory
Fenders Rolled/Altered: No
Does the setup rub?: It does not rub while on OEM springs.
Brake Pads to Keep Wheels Looking CLEAN !: AKEBONO Ceramic Pads !
Pics Below:
(Better Quality Photos WILL be provided)
Wheel Model: Morro
Offset Front: 31mm
Offset Rear: 31mm
Suspension: Factory
Pics Below:
GiveItGas (12-21-23)
Update #2, changes in bold
LS Year/Model: 2007 Lexus LS460 SWB
Wheel Brand: VOSSEN
Wheel Model: CV-1
Wheel Size Front: 22 x 9
Wheel Size Rear: 22 x 10.5
Wheel Finish: Silver/Machined
Lip finish (if applicable): Stainless Steel
Offset Front: et 35
Offset Rear: et 38
Hub Bore size (if known): N/A
Hub Centric Rings Required? Y/N: Yes
Tire Air Pressure Preference: 35-38 psi
Suspension: Tanabe NF-210
Does the setup rub?: Originally it did not appear to on the 265/30/22 front tires. But it was rubbing on both the inner control arm and plastic edge liner on fender...switched to 245/30/22 size and rubbing is gone.
Pics Below:
http://www.flickr.com/photos/71780827@N02/6489858775/http://www.flickr.com/photos/71780827@N02/6489858775/ by http://www.flickr.com/people/71780827@N02/, on Flickr
http://www.flickr.com/photos/71780827@N02/6489857609/http://www.flickr.com/photos/71780827@N02/6489857609/ by http://www.flickr.com/people/71780827@N02/, on Flickr
http://www.flickr.com/photos/71780827@N02/6489856283/http://www.flickr.com/photos/71780827@N02/6489856283/ by http://www.flickr.com/people/71780827@N02/, on Flickr
Wheel Brand: VOSSEN
Wheel Model: CV-1
Offset Front: et 35
Offset Rear: et 38
Pics Below:
jlyrix (01-03-22)
LS Year/Model: 2008 LWB
Wheel Brand: Vossen
Wheel Model: CV1
Wheel Size Rear: 22
Offset Front:
Offset Rear: 38
Tire Make/Model:Nexen 3000
Tire Air Pressure Preference:40
Suspension:Stock
Does the setup rub?: Yes, on left rear with two small passengers, empty tank, and no luggage.
Sounds like its rubbing on the inside...please help, and suggestions?
Pics Below:
Wheel Brand: Vossen
Wheel Model: CV1
Wheel Size Rear: 22
Offset Front:
Offset Rear: 38
Suspension:Stock
Pics Below:
LS Year/Model: 2012 Sport
Wheel Brand: Lexani
Wheel Model: CVX-44
Wheel Finish: Black Machined
Lip finish (if applicable):Polished
Offset Front:35
Offset Rear: 38
Tire Make/Model:Continental Extream DWS
Tire Air Pressure Preference:38
Suspension:Stock Air With Data Systems Controler
Does the setup rub?: No Currentlly Lowered and Driven at Level 4 in front and level 3 in rear
Wheel Brand: Lexani
Wheel Model: CVX-44
Offset Front:35
Offset Rear: 38
Last edited by yodanadane; 02-01-12 at 08:56 PM. Reason: Wrong year of car listed and wrong wheel make and model
LS Year/Model: 2008/SWB
Wheel Brand: Vossen
Wheel Model: CV-1
Lip finish (if applicable)olished
Offset Front: 35+
Offset Rear: 38+
Tire Make/Model: Conti DWS
Tire Air Pressure Preference: 40-ish
Suspension: Tanabe springs
Fenders Rolled/Altered: not yet
Does the setup rub?: YES, rear inner side with passengers in back
Pics Below:
Wheel Brand: Vossen
Wheel Model: CV-1
Offset Front: 35+
Offset Rear: 38+
Pics Below:
