Water at front of trunk -- where to look for entry point?
I am getting water at the very front of the trunk, nearest the passenger compartment. Are there drains in that vicinity that might be plugged causing an overflow there? Any other suggestions? Rest of the trunk is dry. The only wet area is immediately underneath the pull-out "shade" thing that has to be in place for the top to operate. Some indication that the water is coming from above that, since it is wet also.
I would clean all of the trunk weather stripping and then treat with that aerospace # 303 I think that's what they call it. I would pay real close attention to the top of the trunk door panel underneath the middle brake light unit . Get on a ladder and keep the trunk panel held open so you can really see whats going on with the weather stripping in that area. I find if I don't clean and treat mine when I go to open the trunk it sticks to the weather stripping and you can see it pull on it when I just open the trunk .
There is also in the trays that are visable when you open the trunk a drain that has a rubber hose on it
you could try to gently push a wire into the drain hole and see if you can clear out any debri or try compressed air . I don't know where the rubber hoses exit but compressed air may help you find it.
The trough of plastic panels that divert water are easy to clean up
Good luck
Good luck
Location: Formerly Easton, Pa. Bradenton FL, now Osprey Fl.
Johnnycakes good question. I've got the same roblem. It started on the passenger side, but the other day the car was out in a rain storm and both sides were wet. I first thought that it only got wet when opening the trunk lid but that wasn't the case. I guess I got a leak.
Buddy where do you purchase aerospace #303. Hope I don't have to drive to Philly to get some. lol
aerospace 303
http://www.autogeek.net/303.html?gcl...FU6f4AodJQkAXg
I don’t know if this will help or not....
once I had the same problem, took my car to a workshop...they found out that the rear rubber on the low edge of the rear window was bended... they say it might be cuz the roof was opened while things where in the trunk and it did not close well.
anyway they changed it and fix the area where it should be attached to. No water leak after that.
Hope this help.
Hope this help.
Hope this help.
Hope this help.
I took a look at JohnnyCake's car this weekend (per his request - I'm not a stalker), and I found the same problem...
The seal at the bottom of the rear window is coming loose from the body (and it's wet down inside there).
We were short on time but, I think our next step is going to be to get the water hose out and start spraying, to see if we can verify where the leak is...and then work on the fix.
Turboo,
Glad that you found the reason for the leak.....plz note that there are many electronics in the trunk that might easily damage due to water leak and it is expensive to replace. So try to fix it asap and good luck.
keep us updated of your findings and how did you fix it.
As usual pics and tips for our members...thanks in advance.
Investigation this weekend, repair next weekend.
We actually closed Habious in the trunk with a flashlight while I sprayed the crap out of all of the seal areas for a pretty long time. Habious did not see a drop of water enter the trunk.
That leaves Mr. Blister's idea as possibly valid (after a really really hard long rain the drain finally backs up), so we'll take a look at that. We'll also glue down the gasket. Pictures to come.
It would have been nice to be able to replicate the problem which would have aided diagnosing it.
