New isf pulling to the right?!
Old 10-12-13, 09:56 AM
vados2009
vados2009's Avatar
Default New isf pulling to the right?!
Guys I have 12 isf and since day one the car was always pulling to the right when letting go of the steering wheel ( no matter what angle road i'll be on), I took it to the dealer and under the warranty they did alignment which didn't help as I noticed later on. After putting about 23k miles on it and changing the back tires ( that got bold evenly ) I took the car to dealer again for oil change and they said that my driver's front tire is down to the metal on the inside corner but the passenger wears out evenly and still drivable. So my question is, it doesn't seem to be normal for the tire to be down to the metal like that on the brand new car ( after year and a half actually ) and on original tires?! Should I take it to a dealer and make a big deal about it or am I just tripping and its perfectly normal for one tire to be down to the metal on one side only?
Alignment was done 6-8 months ago and it looked good.
Thank you for all your help in advance
Old 10-12-13, 10:01 AM
jjpb5
jjpb5's Avatar
Do you remember hitting any pot holes or curbs? It's kind of late to make a big deal to the dealer.
Old 10-12-13, 10:06 AM
vados2009
vados2009's Avatar
Nah nothing, First day i bought the car from the dealer i was driving it home and noticed it was pulling to the right.... It wasnt bad but noticable
Old 10-12-13, 11:49 AM
thekhmer
thekhmer's Avatar
dang your lucky they even did an alignment for you, most the time they wont do it because thats a wear and tear thing. my 12s steering wheel is crooked to the left a tiny tiny bit but it does bother me and it does pull to the right which is weird..im not sure if i wanna bring it in to do an alignment yet cause im going to lower the car anyways
Old 10-12-13, 11:53 AM
toky916
toky916's Avatar
I have the same dang issue ! Rear got right to the cord
They did ailment and then I came back and told them it's still doing the same thing and they made me go drive with the shop Forman and he said it pulls to the
Right also and they redid it. But contines to do the same thing !
Old 10-12-13, 11:54 AM
toky916
toky916's Avatar
I was just told off by some members on here that it was my problem.
But looks like there are others that same issue !
Old 10-12-13, 01:19 PM
emperors6
emperors6's Avatar
I don't know if linking off-forum is allowed but see:
http://www.lexusfforum.com/forums/sh...?t=1531&page=5
TSB # L-SB-0174-08
Also do a google search for: "lexus is-f pulls to the right"
Let us know if any of that helps.
Old 10-12-13, 01:46 PM
vados2009
vados2009's Avatar
They told me they can do free alignment for me as long as it was within a year or something like that , I think i was passed that little bit but they honored it anyways
Old 10-13-13, 04:34 AM
WillRockwe
WillRockwe's Avatar
Print this out and take it to the dealer
http://www.lambros.net/LexusTechInfo...SB-0174-08.pdf
Old 10-13-13, 08:50 AM
ISFGEORGE
ISFGEORGE's Avatar
that is only for 2008-2009 models. Wouldnt they say your 2012 doesnt have those issues ?
Old 10-13-13, 09:19 AM
thekhmer
thekhmer's Avatar
I'm gunna contact my dealer about it Monday then I'm pretty positive they will even check out newer isfs also. Plus I get a free loaner lol
Old 10-13-13, 11:17 AM
toky916
toky916's Avatar
We'll if the car pulls to the right same issue.
It's the same car why.
Is this just in some cars makes me a bit irritated recently they can never seem to know what's the issue and fix it. Really never had this problem before with my BMW :sigh:
Old 10-13-13, 04:57 PM
Troy
Troy's Avatar
Ours does the same thing!
Old 10-13-13, 10:34 PM
emperors6
emperors6's Avatar
That TSB is a diagnostic procedure. Unless tire and suspension technology is completely different it should still apply :P If you do a google search on the title "Repair Manual Supplement: Vehicle Pulling to One Side", you'll see they have different versions including some for Toyota and even earlier years. The TSB quoted above was published in late 2008 so they just haven't bothered to post another one.
Old 10-14-13, 06:01 AM
VtotheJ
VtotheJ's Avatar
I had this problem on my 08 a while back, thankfully my dealer was able to mitigate the issue with a good alignment (i forgot to get the spec sheet ). I would make the dealer try the following:
  • swap front tires, and
  • 4-wheel alignment
  • 4-wheel balancing
  • front & rear subframe adjustment
  • properly inflated tires
If all that doesn't work, check out this thread I started a while ago: https://www.clublexus.com/forums/is-...placement.html
Mine still pulls right but it's so negligible that it doesn't bother me. There are two caster brackets that can be installed. Since you're a 2012 it should be covered under warranty.
Quick Reply: New isf pulling to the right?!
