wood paneling
Anyone have advice on freshenibg up the interior wood paneling. Mine doesn't look bad but I have a couple of discolored spots. SInce the rest of the car looks new, I might as well bring the wood up to speed. I was told by the Lexus dealer the wood can't be taken off without breaking it. Putting in new wood cost almost a grand, plus they don't want to install it. That means refinishing it but most of looks good. Maybe re-staining it? What do you guys think?
Reggie try using some car wax.I know it sounds strange, but try it on a small spot, and work it in like you would your paint.Most wood kits have a clear coat on the top, just like your paint.If you have minor scratches try some mequeirs scracth X.It takes out scratches pretty good.Show me how it comes out on sunday.
![Big OK](https://www.clublexus.com/forums/images/smilies/bigok.gif)
If the clearcoat on it is worn through, or not glossy anymore, and you can't bring it up with a polish, you can respray it in place. You'd have to scuff it with ~800 grit sandpaper and then use a clearcoat (shaker can will work ) that's available from Dupli-Color or Krylon etc. Just make sure you mask it well and cover your entire interior, seats, dash , windows etc. because the spray will land on everything. A couple thin coats followed by a wet coat should suffice.
Cheers.
Cheers.
