Dings and Lovebugs
Dings and Lovebugs
What do you guys suggest for my front bumper? I bought my Lex used and have some chips on the bumper from lovebugs etc. I can get the lovebugs off but the paint needs work...do you suggest touchup paint? If so, what is best way to apply?
Don't mess with the blotchy touch-up paint bottles. Use a pen-type touch-up paint instead--you'll get better results from thinner coat application and more control of paint flow. Pens are available from:
1. www.autovisuals.com
2. www.paintscratch.com
I've used the touch-up pens on my black '99 GS400, and it works wonders--no bumps like the old-school bottles, just nice flat layers of paint that you build up to match the chips/scratches. Once you use the pens, you'll never go back. . .
FYI (contrary to what you may have heard), Black Onyx is the only body color on Lexus cars that does not have clearcoat. So you will most likely need just the basecoat applicant.
I've done touch-ups using the Autovisuals pen for my black ES300 this past summer, and the results are so much better than the brush bottle method. Here's a link outlining my paint pen experience:
https://www.clublexus.com/forums/sho...threadid=90844
Originally posted by 1ton
Which ones do you recommend? Just the basecoat or basecoat and clearcoat? I have black SC430.
My experience was with Autovisuals pens (I also bought a fine point felt tip for fine scratches), but again, Paintscratch's pens are probably very similar.
Paint repair needed for bumper
I have a Green Lexus with a Gray bumper. I wanted to buy a paint pen to fix the gray paint on my bumper. I found the main green color code for my Lexus but I can't find the paint color for the gray bumper, either on the car or on the autovisuals website. Would I be able to still get a paint pen to fix my bumper or will I have to buy a bottle of touch-up paint from the dealer? Do I have buy the a clearcoat pen as well to make the touchup-paint match the rest of the car?? And does anyone know a Lexus Dealer that sells paint pens cheaper than autovisuals or paintscratch .com?? Thanks
Re: Paint repair needed for bumper
ArmyofOne
Automotive Care & Detailing
12
03-19-09 12:34 PM
