Black onyx & non-clearcoat database info needed from all
#32
so i did "THE TEST" on my 1995 black es300 with original paint. i removed some minor scratches with rubbing compound and a light blue microfiber towel and BAM, black paint all over the wipe. proves there is no clear coat and that i'm scared to rub that same area twice, i may rub all the way down to the metal! maybe, just maybe
#33
#34
I'd not be too worried about the color transfer. That is a normal result of polishing or compounding. As with any abrasive product, be careful, especially around the edges where the paint is thinest. CC is typically, but not always, harder than SS paint but the same principals of correction hold true. Only use polishes and compounds aggressive enough to remove the blemish. You don't want to remove more paint than is necessary to correct the defect.
