All about Lexus leather
#271
No cleaner/ protectant is going to repair that bolster. That will need a few restoration products. That said, using an oily or silicone laden conditioner will worsen the damage so if you are not going to do the repair now, use the LM cleaner and protection cream. The LM Protection cream is water based and won't degrade the topcoat bond to the remaining area surrounding the damage.
Clearly you can see that the constant abrasion of the leather removed the topcoat. The repair will require a cleaning, sanding and respray of pigment and clear coat. This can be a DIY but it may yield more satisfactory results by seeking out an experienced refinishing specialist in your area. This will also require precise color matching and grain lifting to make this damage disappear. These skills are usually beyond the experience level of the DIYer.
#272
No cleaner/ protectant is going to repair that bolster. That will need a few restoration products. That said, using an oily or silicone laden conditioner will worsen the damage so if you are not going to do the repair now, use the LM cleaner and protection cream. The LM Protection cream is water based and won't degrade the topcoat bond to the remaining area surrounding the damage..
#273
The main things are cleaning and hydrating. Keep the leather clean and hydrated and it will last a long time. Use the protection cream to prevent stains, dye transfer and make cleaning easier.
I believe you will find that after cleaning and protecting, the leather will be silky smooth. It will feel and look like new and this will last a long time.
#276
https://www.clublexus.com/forums/showthread.php?p=7580489
#277
I just read through this whole thread and I think I have come to the conclusion that the products I will purchase will be from Leather Masters for the reason below.
I just bought (as of yesterday
) a 2001 LS430 UL with the semi(?)-aniline black leather. The question was asked on one of the earlier pages about cleaning this type of leather but I don't think it was ever clearly answered. I haven't done extensive research through all the brands that were mentioned (Meguiars, Lexol, etc...) but on the Leather Master cleaning products specifically mention it being used on aniline leather.
Hope this helps those others with the UL package!
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
#278
question for you leather experts.
i repurchased an 06 IS recently and the steering wheel is not the same smooth/matte like finish it was when the car is new. it is now more shiney and has a typical hard shiney leather feel. what's the best way to restore back to the matte like finish if possible?
thanks
thanks
#279
thanks
thanks
I'd start with cleaning. You might need to clean it multiple times to accomplish a thorough cleaning. Wipe off the cleaning solution with a white cotton towel after each pass. Use foam applicator to agitate and soft white cotton toweling to wipe up, not microfibers. If the dirt continues to come off on the towel, repeat the cleaning but be observant that dye is not coming off the leather. If you start to see dye pigment on the towel you have more serious restoration issues.
If you are satisfied with the wheel condition after cleaning, apply a leather protectant, not conditioner. If the wheel is not as you want it, I'd suggest you seek out a local restoration expert in your area.
#280
Much will depend on why it is hard and shiny. If it is due to oily or waxy conditioners or skin oils, it is probably able to be restored with proper cleaning. If it is due to wear and abrasion not much can be easily accomplished.
one question though, you say apply a leather protectant and not conditioner? why is that? i use lexol conditioner on my other cars and like how it works. also, what is a good leather protectant?
thanks again
#281
One further point, conditioners do not prevent dye transfer. Protectants do. If you have lighter colored leather, this can be a strong benefit preventing stains from jeans, belts and some other dyed clothing from staining your leather.
One last point... Leather Masters makes one of the best leather cleaners as well.
#282
Hi all, I just want to share that my local Lexus dealers sell Lexol leather products at the dealership. So those of you who wasn't sure if 3rd party products would harm Lexus leather (I was) then looks like Lexol is safe to use.
#284
