leather
leather
My leather needs to be cleaned. I have an 01 ultra... as u know it has perforated holes... If i put a liquid cleaner on the leather im afraid it will go inside the leather... Plus is there a specific leather cleaner i should use (maybe meant esp. for Ecru with perf. holes), or should i go for the Lexus leather care products... All input is appreciated
Thanx
Mink92890
Thanx
Mink92890
I used to own a Coach Edition ES300, which has perforated leather seating. I usually applied leather cleaner/conditioner to the seating, and although little liquid gets into the holes of the seating, it never bothered or concerned me. I have Meguiar's Rich leather cleaner/conditioner, and does a fantastic job in keeping the seating of my current ES looking clean and feeling soft.
Other good leather cleaner products include Lexol, Zaino, and Leatherique. Stay away from Armor-All if you can; they're known to leave behind a greasy residue in all their products.
Agreed lexusk8, Armour All will make you slip & slide if you take a quick corner & you might end up in the passenger seat of hanging out the drivers window.....they should use that stuff on surfboards, that's where they need em lol.
Lexus leather is provided by:
GST Auto Leather (http://www.gstautoleather.com/default.asp)
https://www.clublexus.com/forums/sho...hreadid=115497
They happen to also make the Lexus brand leather conditioner (it's lanolin based). I've used the Lexus brand conditioner and I can say that it works excellently--better than the leather conditioners by Meguiar's, Eagle, and Lexol.
thanx for the info... SeattleGS400, where can u purchase the conditioner made be GST auto leather...Can u only buy it from the dealer, or can u get it from GST auto leather directly... If u can get it from them it will probly be cheaper than if u have to get it from the dealer (markup's, etc.)... Does it work well, my seat is starting to turn black, can this product remove it. if not could u tell me some product that will remove the black...
Thanx
Mink92890
Thanx
Mink92890
Thanx
Mink92890
Thanx
Mink92890
There is a Lexus leather cleaner, but I don't how much it costs, but it's probably similar in pricing as the conditioner. For lighter color leather as you have, I would look into using the cleaner before using the conditioner. That is, after you vacuum, and wipe the seats with a warm/hot, damp terry cloth, spray the leather cleaner onto a clean terry cloth and wipe small sections of leather until the dirt and grime is out. Then follow-up with another damp, clean terry cloth over the cleaner-applied portions. Once the panels dry up, make sure that you follow-up w/ the leather conditioner as the cleaner will leave your leather a little dry.
Good luck!
thanx so much for ur help... The driver seat looks so horrible, esp. because the leather on the other seats r like perfect. will it be cheaper in lexus-parts, or will it be better (cheaper) if i get it from the dealer
Mink92890
Mink92890
The "care tag" attached to the the passenger seat when I bought my '03 LS new says the following:
"When removing stains or dirt: Do not use solvents such as thinner, gasoline, or acid or alkaline solution, as these may cause discoloration and/or staining"
"How to remove dirt: 1) Remove dirt using a soft cloth dampened with 5% solution of neutral detergent for wool. 2) Wipe off traces of detergent with a clean, damp cloth. 3) Wipe off moisture with a dry soft cloth, then allow to dry in a ventilated, shaded area. NOTE: If stain should fail to come out with a neutral detergent, apply a cleaner without containing an organic solvent."
Just thought I would share this as most probably have never seen the tag or else threw it out shortly after taking delivery. The thinner/gasoline thing is probably obvious but the 5% wool detergent isn't. It works very well and is a heck of a lot cheaper than buying cleaner from Lexus (which probably is the same thing)
Woolite & water mix has been recommended by some manufacturers,.in their owner's manuals, for years now (Cadillac etc.) and there are a lot of people at Autopia using it on their leather too. Very gentle, yet effective on light soil. You can vary the concentration for heavier dirt, but usually 6:1 works fine (6 parts water 1part Woolite)
i place an order on lexus-parts for the leather care and conditioner. I used my Clublexus discount !
hopefully it should come by tuesday! i figured u can't go wrong with cleaner made by the maker of the leather. Thanx for ur guys feedback...
Mink92890
Mink92890
Question, After reading thru all the archives, I read that alot of people use different leather conditioners, from Zaino, Lexol, Lexus brand and others.
I bought the Zaino leather in a bottle and bought the Lexus leather conditioner.
Question are both safe?
The Zaino smells better-like real leather smell.
The Lexus bottle smells more like coconuts.
I'd rather use the Zaino but don't know if it's safe for Lexus leather.
