What is the best way to care for diamond polished wheels??
Any detail gurus:
I have a set of diamond polished aluminum wheels with high-polished, clear-coated lips coming in a few days. I am wondering about the best products/process for keeping them looking good. I haven't mounted them up yet, so I'd like to get a head start on caring for these babies. I have heard about the possibility of them dulling after a while.
Any advice???? Thanks.
Eric
Eric
Eric, the regular use of simple car wash shampoo is all you need to keep them clean. NEVER use any acid based wheel cleaner. Avoid even highly alkaline (Simple Green -Castrol Super Clean etc) cleaners, especially on warm or hot wheels, unless you dilute them at least 50%.
If the wheel has a non clearcoated polished part, it will dull over time, and you can use an aluminum polish or NevR Dull, Wenol, etc. to bring it back up. You can also have them sealed with Zoopseal or a similar product if you're so inclined, and never have to polish again.
One other thing you can do is daily (or every other day) spray them down with a quick detailer, and wipe dry. Once they get real dirty you would be best to wash them, but very light brake dust can be removed via the quick detailer without scratching.
A polymer sealant ( Zaino, NXT etc. ) will also protect them and make them easier to clean. I don't recommend wax in the case of wheels because it melts at or below 165 degrees, and rims can get pretty hot with constant braking going on. Polymers hold up to ~400 degrees Enjoy the rims.
Thanks, Guitarman!!!
Somehow I just knew you would be the one to come through for me.
A polymer sealnt definitely sounds like a good idea. Are there quality products in this category that are more easily attainable than Zaino's for instance? Something I could acquire at an auto parts store, for example?
Also, would I be safe using such a product on the entire surface of the wheel, be it the lip or the diamond polished center?
I'm not familiar with Zoop seal, but I did catch somewhere that it is pretty costly. Guess I'll do some research on that product first.
Thanks again!!
Eric
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Thanks again!!
Eric
As far as off -the- shelf polymer products, here are a few to look for;
Liquid Glass (acrylic polymer)
Meguiar's NXT
Finish First
Meguiar's # 20
NuFinish (acrylic polymer)
Meguiar's NXT
Finish First
Meguiar's # 20
Pattiwack
Automotive Care & Detailing
01-27-16 12:21 PM
teejnut
11-21-06 04:22 PM
