Tar
Originally posted by BA_GS400
I can unequivocally guarantee you that both Kerosene and GooGone will NOT hurt your paint. You will strip the wax finish off of course, but your clear-coat will be factory perfect.
Both are excellent at getting tar/bugs/gummy/sticky things off. The kerosene is cheaper, but the goo-gone is more handy in it's little bottle. It's actually a CLEAR plastic bottle (around 6-8oz) but the label is a black background. HomeDepot and Lowes have it as well.
Master Thread Closer!!
I use this spcial paint acrylic cleaner...great stuff...takes out everything with ease....paint overspray, tar, gum, tree sap, etc......LOL!!! Main thing is to wash it down ASAP when done cleaning ....then slap on a coat of wax (Zaino for me).
Its actually similar to the cleaner provided before putting on the TTE front lip.
Pete
Pete
The only thing to watch out for when considering all these different types of solvents to use on paint, is whether they contain xlyene ( pronounced "Z-eye-leen") because the paint manufacturers cite it can cause damage to clearcoats and urethanes, notably crazing/checking (tiny cracks in the paint) and not always right away - it may take a year to develop. Gasoline has xylene in it, lacquer thinner, even kerosene has a tiny amount ( about~1%). Kerosene was used by many on paint years ago when lacquers were used to paint cars, but yesterdays' paint is quite different than what's used today. Goof Off also contians xylene, as well as some bug & tar removers, Armor-All's version is a case in point (yeah-that IS surprising to even me ).
This doesn't mean that anything with xylene in it will automatically cause paint damage, just that , depending on the concentration, the risk is there. Some paints are more susceptible to different chemicals than others too, so there's no hard and fast rule, just a general caveat on xylene to be aware of. Some people may have seen that paint can be damaged near the filler cap of some cars when gas is overfilled or spilled on a frequent basis, well, that's the xylene in it causing dulling and micro - checking.
I would suggest the use of WD40 to remove tar, because just about everyone has some around the house, and it contains no xylene. It works fast on it too. Cheers.
The One
BTW, Dan, I'm moving the thread to your area as it is more your domain.
exclusive matchup
Originally posted by Neo
Really? That's good to know. Thanks Dan.
man, you can just call and ask me
Hi all, since you guys are on this tar removing subject.
Normally I use a bit a clay and Zaino Z6 to wipe off the tar, it works pretty well for me.
But is that a good idea? or should I stop doing it?
thanks
thanks
