DRL scratches?
DRL scratches?
Sup All,
Is there something available to fix scratches on the DRL? One of my DRL has some scratches, saw that today while washing the car... now the interesting thing is that these scratches were exactly under some bird droppings.... Is it possible for bird **** to corrode away plastic?
I'm not a big fan of maguiers, personaly I use 3m scratch remover, its more expansive but it works 10000 times better, I remember trying to buff out scratches with meguiers and it looked even more hazy then before, and 3m makes it look brand new. But ofcourse you will need a buffer to make it look good, doing it by hand wont give you the result your looking for.
Ya, 3M has good plastic polish. There are two bottles to buy: plastic cleaner (has some grit in it to remove scratches) and a plastic polish (very little grit to make plastic nice and shiney). Use the cleaner first then follow up with the polish. If you're in California, you can find them at Napa Auto Parts.
If you have plastic covers just remove then and get new once Im not sure you can buff those out, and no elbow greece wont give you the satisfactory result you are looking for, you can buy a buffer for 20 dollers at homedepot, its a worth while investement, if you can figure out how to buff out headlights or even sand them down and buff them then your set for life.
You can also try wetsanding the headlights to remove the deep scratches and then polish it to remove the sanding marks. It's worth a try before you go and buy new headlights.
Here is a thread that discusses the process https://www.clublexus.com/forums/automotive-care-and-detailing/63690-how-to-remove-scratches-on-headlight-caused-by-sanding.html
Actually, no scratches on my headlight covers ... just a nice faded "coating" that makes them look anything like new. Still recommend 3M? Still recommend a buffer vs. elbow grease?
Master Thread Closer!!
i just scraped my plastic headlight covers against a portion of concrete wall that protrudes out a bit.....not deep at all...but the clear plastic is not frosted white looking......i stop as soon as i noticed i was scrapin it.
What do you recommend i do to take repair it.....wet/sand with 1500 grit....then with 2000 grit....then scratch remover....and finally plastic cleaner and plastic polish?
Please reply if this is my best bet in removing.
Thanx ppl.
Pete
Thanx ppl.
Pete
Well....since no replies...i just went ahead and 1500 grit wet/sand...then 2000 grit...then rubbing compound...and lastly a finishing glaze........looks like new again.
