scratches worse after clay/wax
Guest
Posts: n/a
I washed my car with meguiars Gold class shampoo with new new microfiber wash mitts (separate towels for top and bottom) I then used the clay magic clay bar (with lubricant) on the hood, trunk and spoiler. I then used Zaino pre-polish and then applied the Zaino polish/wax.
After I buffed every thing off with several 100% cotton towels (different towels for top and bottom), I had a ton of micro scratches and wax residue. The paint looks considerably worse than it before.
I've had this problem with every car I've washed before which definetly tells me it's in my method, or the product I'm using.
Any ideas? I feel like I've ruined my paint/clearcoat.
Originally Posted by chicagoblknazn
I always say never use a buffer....do everything by hand.
Also, did you use Z2 or Z5? I know Z5 is supposed to fill in swirls, but I found that it won't eliminate all swirls. Like a previous poster said, investing in a Porter Cable is a good choice. It's a pretty safe way to eliminate those pesky swirl marks.
What color is your car? If it's black, then it's going to be difficult to always keep the finish perfect. Washing your car will likely induce surface scratches. Polishing with a PC every 6 months or so is the best way to keep the finish looking brand new. Good luck.
I've had a similar problem... lots of streaks on the car where you rubbed the clay bar? You''ll likely need to use some scratch-X or something similar to get those off.
The problem likely is - (I haven't tried to clay again myself since this (paid my detail guy who is much more proficient than me)) - that you didn't use enough lubricant when you clayed the car. It needs to be really constantly wet not to leave marks. You also need to fold / turn the clay very often. If you drop it, toss it.
What are you drying your car with. I'd highly recommend a waffle-weave microfiber drying towel. Chamois will scratch as will cotton towels. Microfiber towels come in various quality grades. Get the best as they are worth every penny. Use microfiber towels to buff off the polish and wax. They can remove the residue with a couple of swipes where cotton towels seem to require much more pressure to get the same results.
Originally Posted by jfelbab
You missed a stage in the process. After claying you need to use a polish like Meguiar's #80 or ScratchX. After removing the swirls you then can finish off with your process. If you don't want to polish you need to use a product that will fill the swirls. You could use Meguiars #7 Show Car Glaze to fill the swirls but Zaino doesn't bond well over a glaze. In that case you could use NXT Tech Wax which also does well at filling swirls and bonds well over a glaze.
Don't use terry cotton towels sold at Walmart & Target. They are made of low quality cotton and will scratch. Get the expensive stuff from JCPenney or Bed, Bath & Beyond. Your car will thank you.
You'll need some scratch remover to repair the damage. See other posts for product recommendation.
tmf2004
Automotive Care & Detailing
14
06-06-07 04:28 PM
