Jade Green Lexus 93 SC300 - clayed w/ swirls
I’m about to use my Porter Cable for this 1st time on a car I bought this week. It’s a 93 Lexus SC 300, color is ‘Royal Jade Pearl’ – a dark green metallic. I have washed her twice (Dawn) and clayed the car. There are light swirls over most of the finish, and a very few light scratches. The paint is in excellent condition for a 12-year-old car (owner had 2 covers, one indoor, one outdoor. I will finish with Meg’s gold class. Here’s the question, I have PB’s 2.5 and Meg’s 9 and would like to know which would be better, and would one work or the other work better with the wax. I have a lot of pads, and have used RO’s and rotarys. I’m looking for maximum durability in minimum time. Thanks to the knowledge and generous participants of the site.
if it's a random orbital buffer, you should be ok. Keep it on a slow setting, and take it slow.
I'd check out autotopia (sp?) they've got some professional detailers over there and some great reviews & threads on orbitals & their usage.
For the swirls... maybe a 3M cocktail will do the trick?
Originally Posted by Dx3
I would never use a buffer on my car - that's the reason a lot of the times for the swirl marks. Do it by hand.
Jonny
Jonny
To the OP's question at hand. With the two polishes you have, use the PB first with a polishing pad. Follow with #9 and a finishing pad. My choice of polishes... I would use Meguiar's #80. If there were defects remaining after polishing, I'd step up to Meguiar's #83 then go back to #80.
When polishing with a PC apply a ring of product to the pad and dab it on the paint over a 2' x 2' area then turn on the buffer with the pad in contact with the paint. Begin with a slow speed (2) and work the polish to evenly spread the product over that area. Then increase the speed (5) and work the polish until it goes clear or nearly dries.
Don't polish or wax a hot finish or in the sun. A good aid when polishing is the halogen work light mounted on a tripod. I use a dual head 500 watt unit that telescopes to 80 inches. Higher is better. This light will allow you to more easily see defects and swirls.
You can use the PC for application of wax as well. If you do use the PC for this use a finishing pad at a slow speed (2)
Edit to add: Your Jade Pearl paint contains a tinted clear coat. You may see some color on your pads from this. Not to worry.
Gears12
Automotive Care & Detailing
12-30-13 10:41 AM
