Need Help!! Spilled Cell-Tech???
Firstly you have to be cautious of the color of your carpet? Some carpets will lose their color with certain chemicals, this is called color fastness. You need to find a chemical from a local janitorial supply house that contains tannin. This removes stains like blood, ink , urine, tar etc...
Again you would have to test in a hidden area for color fastness. Lastly I hope you haven't set the stain in with the other chemicals you tried. If you did your final chance would be to re dye the carpet with the color of your carpet to match.
Hope this helps
Hope this helps
