ran over a paint puddle and now its getting to me
this happened pretty long ago fyi. i was driving one night on the highway. didnt noticed until i came home and saw the right side of my car covere din splats of white house paint. i quickly cleaned it off and even used gasoline to loosen up the paint. most of it is off, but there are still specs on it. i was just wondering is there ANYTHING else that can take this off? i tried alcohol and even gasoline. this week i will try paint thiner if possible. my door, part of quarter panel, wheel well, fender r covered with these annoying specs. everytime i wash my car and go out everyone tells me that my car is still dirty. but it is not. godamnit im sad. please help.
Use a very lightly coarsed rubbing compound.... I had some pearl over spray on my SC's front end and it took it right off, plus it only removed the wax and I just had to throw some back on and it looks like new! try that before a clay bar.
oops! sorry. but i remembered, the only thing that actually WORKED was a plastic spoon. i scraped it off like i was digging in a goldmine. do u think a claybar should work tho? if it should, i will pick one up tomorrow.
Yeah use rubbing compound then give it a good polish. Then after that you should wash and wax your car
I got some paint on my car onetime from the leatherseat paint, finally got it off with scrubbing and rubbing compound.
my 300 had a dent and friggin bright neon yellow paint on it from the previous owner's brush up against a parking lot pole....a little bit of that aerosol brake cleaner and it is 100% gone.
Originally Posted by xknowonex
i had major overspray on my last car while tinting the tail lights. I took it to the shop and they wetsanded it. I looked much better than before
Try using 2000 grit sand paper and wet sanding off the paint. Then using a rotary buffer buff the area out with 3M polishing compound.
I guarantee the parts you polished will look better then the rest of your car.
im scared to use sandpaper on the area.its not that serious, but its annoying looking at it . its just a bunch of specs randomly covered all over the right side. should i still use 2000 grit sandpaper? scuurrddd
