Perforated seats w/ ventilation: different practices for conditioning leather?
I don't have perforated leather seats, much less ventilating seats, at the moment, but I did drive an 06 GS300 loaner car a couple days ago with ventilated seats and loved it. BUT, I've gotta say, I'd be really worried about using leather conditioning on them as I'd fear that I'd build up some kind of blockage in the holes, or worse yet, have conditioner seep inside the hole and block the path where the air comes from inside the seat (something much harder to correct I can only guess?
With something like Zaino or any other thick/cream-based conditioner I don't think this would be too much of a concern... just keep it thin. But with something like leatherique which instructs you to apply liberally and leave it sitting there for a few hours, and particularly something like leatherique because it's very liquid... I'd be very worried about the stuff going down there and hardening and blocking the air flow.
Is this a legitamite concern and if so how do you circumvent this problem?
I think it could be a concern. I honestly don't know the mechanicals/technical side of ventilated seats, but I do know that perforated leather and waxy / thick conditioners are problematic. Usually you can just use some compressed air on them to remove the offending buildup.
You're correct in that some conditioners are worse at residue than others, so Zaino or even 303 Aerospace protectant would be good choices, the latter being no problem at all with perforations.
If someone can explain the tech side of the active ventilation in the newer seats, we may be able to determine whether or not conditioner buildup would be deleterious to them or not.
For simple perforated leathers, it's merely a nuisance, although I personally think having conditioner stuck in there will lead to dirt build up faster. Hence the reason you'd want to blow it out if possible.
The perforated leather provides ventilation and prevents slippage.How to for perforated leather...
[QUOTE=I honestly don't know the mechanicals/technical side of ventilated seats"[/QUOTE]
air, cleaner, clogged, coffee, conditioned, conditioner, leather, lexus, perforated, seats, sets, spilled, ventilate, ventilated, zymol
