Arrgh...Swirl Marks
I've only had my black IS350 for a week now. I've only washed it once through a touchless automatic carwash, then spray and wiped with Meguiar's Quik Detail with 3 microfiber towels (switched them off when they got too dirty). To my surprise, I noticed fine scratches already.
How can I avoid this? I'm not too educated on detailing, but I always assumed if you use microfiber towels you can avoid swirl marks and fine scratches
sorry to hear man! use a high quality shammy, I use it on my black Impala SS and it leaves NOTHING! good luck! throw a coat of wax over it as well to avoid clear coat scratches.
Wax doesn't prevent scratches - just protects from the elements.
MongooseGA is right, it was likely the touchless wash. I'd investigate some how-to's on washing your car yourself the right way. Black is tough, but it can be done if you do it right. Also keep in mind Japanese paint is generally soft, so only quick detail when necassary - even the most innocent quick detail with microfiber can leave scratches. Make sure you're using good mf clothes too - there are a lot of cheap ones with polyester threads in the seams which absolutely mangle paint.
How can I avoid this? I'm not too educated on detailing, but I always assumed if you use microfiber towels you can avoid swirl marks and fine scratches![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Sorry to hear that you had the problem especially with a BRAND new car. I got some scratches and swirls from an auto carwash that I used to go to. Tought that the touch free would be coo, until I started looking into it and man....just bad news especially for a black car.
best of luck to you.
So it sounds like the touchless car wash might have done it. Amazing...I thought I'd be ok since it's touchless...I mean how can high pressurized water scratch your paint? Oh well....
Now that I have this fine scratches, how do I get rid of them? I noticed that Meguair's sells a Scratch X product or something. Should I use that?
Are the scratches all over the entire car? ScratchX will work, but it requires some elbow grease and a little finesse to not induce more marring. If the swirls are just in isolated areas give that a shot. If they're all over the car you can either hide them using a glaze or wax with fillers, or have them removed via polishing. If you go the entire car polish route you may consider having a detailer do it unless you're a DYI kinda guy, in which case you can learn the in's and out's of polishing over at autopia-carcare.com's "how to" section.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Morrisey,
Please try the search feature in this forum and you'll find loads of info with no waiting! The swirls on black question has been discussed very extensively! If you'll try the search feature (I used 'swirl black' and pointed at this forum) you'll get a lot of info immediately with no waiting
https://www.clublexus.com/forums/sho...ht=swirl+black
https://www.clublexus.com/forums/sho...d.php?t=124749
Some of these will probably have more 'extreme' solutions to swirls than you'll need with such a nice new car with limited damage
Thanks Dave, didn't realize it was such a major problem. I'll search next time I make a topic.
I guess the biggest dillema for me is that Denver gets pretty cold this time of year. It's by no means freezing, but the average day temp is 40-45 degrees, which is too cold for washing the car myself. So I either have to take it to a car wash (which obviously isn't a good idea on my soft black paint), or just leave it dirty for weeks at a time until we get a warm weekend
O.C. Lucky Strike Fanatic
Owning a black car is full time job. lol
I usually take off my fine scratches with meguiers scratch X and it does require elbow grease.
A trick to prevent scratches is to dry your car the direction of where the water slides off the car.
LexInTex
Automotive Care & Detailing
17
03-08-08 12:48 AM
VEGASRX330
12-27-04 07:32 PM
