question's on using a buffer?
is a buffer safe for my black lx470? , and also how do i use it? is it better than hand wax?
plus is this a good buffer http://www.autobarn.net/vec235.html if not can you guys tell me which one can i get from auto barn .
thanks alot
thanks alot
thanks alot![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
thanks alot
Get a Porter Cable
thanks alot
oh ok thanks, what is a really good scratch and swirl mark remover? that i could buy from auto barn and i dont want to get a really expensive buffer because it's my first time using a buffer, when ill get use to one ill go on to the porter cable . thanks for the help
oh ok thanks, what is a really good scratch and swirl mark remover? that i could buy from auto barn and i dont want to get a really expensive buffer because it's my first time using a buffer, when ill get use to one ill go on to the porter cable . thanks for the help ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Good Luck
I second what cantsleepnk said. If you are not going to use a quality buffer that uses orbital action and high quality pads you may just regret it. I've seen the results from friends who brought me their car to repair after they hosed the paint with an el-cheapo buffer and a wool pad. IT was much worse than before they started. If you are not going to go the Porter-Cable route and are thinking of the cheap buffer forget it and do it by hand. The other option is to take it to a professional but for the same money you can buy a PC.
Seriously you should save your money. Use that 25% off coupon just posted and get a Porter Cable, I just got the whole top of the line kit with polish for $150.
I made the same mistake you are about to make and bought a Craftsman buffer / polisher it is worthless. Not to mention with the cheapo ones they vibrate so much after an hour you feel like you just did it all by hand anyway, get a nice expensive balanced one. You'll use the cheapo once and vow never again.
http://autopia.org/forum/showthread....ht=black+lexus
http://autopia.org/forum/showthread....ck+lexus+rx300
