just bought the PC 7424, need polish help
I just purchased the 7424 fom coastal tool, with the 6" weight and backing plate bonus, and some Lake Country white and red pads.
I have a white 2001 LS430. I am having trouble deciding which polish to use. I have heard a lot of good things about Zaino, but apparently I don't need the buffer with the Zaino?
Should I return the buffer?
Or should I use a different polish with the buffer, like the Klasse AIO, and put Zaino on top by hand? I wanted to try out the buffer because it sounds fun but I don't want to be wasting my money either.
The PC is great for lightly working the paint and applying polish in a nice thin even coat. It also speeds things along compared to applying and removing wax by hand. Although, I actually stopped using the bonets to remove the wax, after doing so many times, I find it easier to do it by hand. I use Meguiars products, and have always gotten great results, even from their consumer product line. I have all the pro line to now and you can ask anyone who has seen my car, it is always looking good.
Good luck,
Good luck,
I made a decision and a purchase.
I will start with Menzerna Final Polish followed by Zaino. I picked up some Ultra Fine Microfiber towels from Pakshak also.
Can't wait till all this ish comes in the mail!
Your choice is a good one, that will work. I know *some* people have said they apply Zaino by PC, but I think it's better hand applied with directionality.
The PC will work well with the Menzerna Final Polish, let us know how you do.
Everything in Moderation
I was considering the exact same thing, since I just got a Porter-Cable buffer as well. But will this polish really be OK under the Zaino? I thought I read that the Menzerna polish had some oils added to it to increase its work time or otherwise make it easier to work with. If it leaves anything on the surface, isn't it no good to use under Zaino???
I think I have to wash the car again after I polish with the Menzerna, then lay down the Zaino.
