A little how-to on chip repair.
I got it online direct from Meguairs. It's kind of expensive, but a pack of 25 or 50 sheets lasts a lot time and, imo, it's totally worth it. I hope this helps.
Originally Posted by skiptomylo
would 3m paper be ok to use?
[n00b question] What's a PC? I'm assuming it's not a personal computer... some sort of polishing tool?
I'm looking to get rid of some minor rock chips and dings, primarily one on my door, so I was gonna give this a go on my bumper before I did the door.
When do you use 2000 grit and when do you use 3000 grit? I didn't see mention of specifically using one or the other. Also, just so I don't freak out as I'm attempting all this... after you do the sanding, the blob should be gone and there will be very minor marks from the sandpaper, that's why you do the polish... the polish will get rid of those marks, yes? The worst thing would be to have a heart attack after making tiny scratches and never getting to do the polish that would fix it right up.
A PC is a Porter Cable 7427 or 7336 - a dual action polisher commonly used by DIY'ers because it works well and is relatively fool-proof.
As a novice I would use 3000 unigrit only. It is much more difficult to mess up with 3k grit as opposed to 2k grit. Yes, after sanding the blob should be level however the sanding marks will look rather intimidating - this picture says it all:
If you've remained cautious and checked your work often even though it looks bad it should polish out relatively easily. 3k grit marks are very fine. If you have any other questions let me know.
![](http://gtaindetail.com/fp/blackg35sedan/rearfendb1.jpg)
can you buy sonus or poorboy products in stores or is it online only? What are good retailers? Thanks!
There are definitely alternatives. For example, Menzerna IP and FPII would suit well, as would Optimum Compound and Polish. For locally available Meguairs #83 (DACP) and Meguairs #80 (speed glaze) would also serve well.
Cheers.
are those good for by hand applications? Thanks for the help!
which is better: Meguiar's ScratchX or Sonus SFX-3?
