Secrets - Wheel Wells and Engine bays
Hey guys, looking for products to clean/detail wheel wells and engine bays.
Can some of you pros out there share with us inquiring minds......thanks.
Wells I do when I clean the wheels and tires. I spray simple green automotive (make sure it's the "auto" kind, since the regular version can dry rubber), cut 2:1 with water into the wells and let it dwell for ~30 seconds to a minute while I clean the wheels. I then take a wheel brush or cloth and agitate where I can reach, then spay with water. Later, when I'm almost done the car (dressing tires, etc...), I spray some 303 into the wells (a little goes a long way), and just spread it. They get dirty relatively quickly regardless of what you do, but the 303 will keep them black for awhile.
For engines I cover up intakes and electrics with tinfoil, spray simple green auto (full strength or cut 1:1) over the entire engine. Clean tough areas with a cloth then lighty spray the engine with water to remove all the residue. Either wait for it to dry or turn the car on for a few minutes to speed it up, then dress with Dress It Right, 303, or Megs 40. I use regular metal polish on metal.
Hope this helps.
Originally Posted by picus
My process for both is the following:
How about this?
http://www.griotsgarage.com/catalog....1002&SKU=11138
I have had good luck with their Rubber Cleaner, Vinyl and Rubber Dressing, and Interior Cleaner - very good products!
Hope this helps.
Hope this helps.
Protectant - the same stuff you use on plastic trim. It keeps them dark for a couple days.
Another note - I've been using dilutted Poorboys APC lately instead of simple green, works better imo and is much cheaper.
Griots stuff is good too, definitely will work.
One of the few things I use a pressure washer on is the wheel wells. I also use it on the tires. I dress the wells with CD/2 Engine Detailer. This is an acrylic based dressing that dries hard and non-oily so it doesn't attract dust and grime like an oily dressing will. It also lasts through rain. I get a couple months out of an application. This stuff (CD/2) is also my go to engine dressing for the same reasons.
Where do you buy this from??
