layering meguiars wax products
I doubt it, and generally as a rule I try to avoid mixing different types of waxes as they all seem to have a slightly different formula. I don't KNOW that mixing waxes does any detriment to the overall effectiveness as a wax, but I like to play it safe.
It depends on what your definition of "better" is. I find that NXT x2 (12-24 hours in between coats) gives me the best results for my needs.
I've topped NXT with other waxes with good results. Just remember to allow the NXT to cure for 12-24 hours before topping it with another product.
If you want high gloss and sharp reflections then I'd stick with NXT x2 (12-24 hours apart) by itself. Navy blue is a darker blue, right? If you want deeper, richer reflections (which is often the case with darker colors and red) then I'd top the NXT with a good carnauba. I'd suggest something like Natty's Blue or S100 (which can be found at your local Harley Davidson store. Whatever you use to top the NXT (if you choose to top the NXT) be sure to let it cure for at least 12 hours.
Thanks
