Why all the Swirl Mark Complaints?
Originally Posted by DaveGS4
Me either. I suspect it's just fine on other colors other than Black Onyx... it just shows every little thing every time you touch it with a swirl, scratch or spiderweb.
My Black Onyx at 2100 Miles already is showing a ton of Swirl marks. I'm at a loss how I could treat it better.
But it sure looks nice right after a wash! Just starts to show everything soon thereafter
I use to wash my car all the time. I was a detailer, but for my GS, i neglect it since it's impossible to keep the car swirl-free when my neighbor has a big tree toppled over my car. Leaves fall on it all the time.
Though I do use the Meguiar washing mit (the tan one, not white. too lazy to look up the name).
Swirl is unavoidable, even if you're the best detailer.
My red is250 has the same scratch problems. I took it back to the dealer and had them buffed out. After washing my car with a microfiber mit and drying with absorber I put a coat of gold class wax on using a sponge applicator and a microfiber cloth to remove the haze. Scratches appeared again. In my opinion there is a problem with the clear coat . I tried to remove the scratches with scratch x and more were created. Swwms like there is no way to prevent them.
Swirls on dark colors are challenging but not impossible to remove or diminish significantly. Using a glaze will hide swirls as well. Some wax product will also make swirls less visible.
I use Meguiar's Speed Glaze (#80) about once a quarter with my Porter Cable polisher to remove any swirls. If you have a dark colored car find swirls annoying you should consider buying a Porter-Cable polisher and some pads. Using a PC makes swirl removal ten times faster and easier. I use Meguiar's Show Car Glaze (#7) to fill any remaining swirls and yield that "wet paint" look. I cover the glaze with Meguiar's NXT Tech Wax (x2) which also has some hiding ability. When finished with this routine swirls are non-existant.
Many times swirls are not removed but only filled in with oils that are removed when washing. Whether you pay someone to "remove" the swirls or polish out the swirls yourself I would recommend checking to see if they have actually been removed or just filled in before applying any sealant or wax. Simply use some Isopropyl Alcohol or paint cleaner on the area to remove any fillers to see if the swirls are actually removed or just temporarily covered up.
Many new cars come with dealer induced swirls to start with that may or may not be hidden. You have to polish out the swirls instead of just covering them or they will keep coming back.
Of course anyone with a black or red car is fighting a much tougher ongoing battle with swirls since they show so much easier on black and red. If you have black or red and want to be swirl free you pretty much need to buy a PC and some polish and be prepared to polish your car a couple of times a year. Removing light swirl marks with a PC twice a year with a light to medium grade polish is pretty easy and risk free with a PC and will not degrade your clearcoat enough over the long term to even notice.
The problem is'nt swirl marks, it's straight line scratches. Yes you can remove/repair them but the problem is they should'nt ocurr in the first place if you wash and wax the car with care.
