Is it alright to wax the headlights?
just wondering if its actually ok to put carnauba wax over the plastic headlight covers
just to protect it a bit better and prevent oxidation
or should i be worried that it will haze?
i use collinite #476
I always wax all 4 of my headlight housings and my taillights.
cool thanx
so u use NXT to wax them?
another reason im asking is also because of the fuss avoiding getting wax onto light plastic covers when im waxing the car
if i dont have to avoid waxing them, thats great
I wax the whole car always, windows and windshield and headlights and taillights everything. sometimes some brands of carnauba wax will leave a film on the glass after you wax, but if it does then you can just wipe the film away with a duster or microfiber.
Guys,
This may be beneath almost all of you...but. Wifey had this vintage Subaru wagon when we took up with each other. I wouldn't buy one of those things, or so I thought. It was very rough: dented doors, dead paint, tint bleached out of the glass, ac on hte fritz, filthy and headlights SOOOO oxidized that they did not light up the road in th least. A real hazard. She doesn't drive at night so she never missed the ability to see after sunset from inside the car. Librarians, go figure.
I took 400 grit sand paper to the lens untill I no longer was generating this milky slime. I then moved to 1000 grit untill I couldn't see the 400 grit scratches. I the power buffed the lens with "Nufinish". If they were on my SC I would be shopping but they aren't. They now throw enough light for me to drive 75MPH and at least identify what I am about to hit.
Point being....these things do clean up. Please note that the lights have some sort of coating on them and that is what yellows and what you have to "sand" away.
For what its worth.
Play safe and hard.
John
For what its worth.
Play safe and hard.
John
Wetsanding definitely works. I use 800-->1500-->2000 grit for the job. When it's all and done, the headlights are smooth and clear. I use a rotary buffer with the 3M rubbing compound to get the light scratches from the sanding, and then finish it off with Meguiars PlastX. Of course I use different pads for polishing and finishing.
__________________
![Name: clublexus-sig-1.jpg
Size: 27.8 KB](https://www.clublexus.com/forums/attachments/automotive-care-and-detailing/441388d1501411427-is-it-alright-to-wax-the-headlights-clublexus-sig-1.jpg)
1999 Lexus GS400
-Stock
MUAHAH
__________________
1999 Lexus GS400
-Stock
MUAHAH
vintagelex
03-05-13 05:22 PM
