Zaino after Simoniz System 5
I recently purchased a certified, pre-owned 2002 Lexus ES300 and had Simoniz System 5 applied at the dealer (no need to remind me this is a rip off, I know that now). Having read this and other sites I am interested in using the Zaino line for detailing. My questions are whether I can use the Zaino products on top of the Simoniz and if so how long I should wait before doing so? I'm looking for a time frame though know it will be somewhat determined by observing the car's finish. I know the Simoniz has a 5 year warranty but it sounds like it wears off long before then.
I would do the following:
Wash the car with Z7, clay with Z18, wash again with Z7, the polish with ZPC to remove the Simoniz, then do ZFX and Z2 or Z5 combination.
The 5 year warranty is a pack of lies.
Thanks to both of you. Jim, can you recommend some OTC waxes to use in this situation?
Another product I'd also suggest is Meguiar's #26 High Tech Yellow Wax. This is a pure wax without cleaners so it wont remove any of the Simonize product already on the car. It is mostly white Carnauba wax and as such doesn't last as long a a polymer sealant.
I'd steer clear of cleaner/waxes as they might remove most of the expensive Simonize treatment you just had applied.
I would not recommend the #26. It darkens the paint quite a bit. I used to use it on my old ES so I have lots of experience with it...years in fact sadly.
It's also well known that Jim and I have very different views on the performance of Zaino versus NXT-I simply don't think NXT looks as good. If you want to go the carnauba route then I would recommend P21S. You can find this at local boutiques or as S100 at your local Harley Davidson dealer. This wax won the Guru Reports wax test for carnauba and its the choice of many experts and it is very easy to apply and remove. Very clear as well.
I do honestly believe that you will be much happier in the long run removing the Simoniz and putting on a better quality sealant. You will achieve more clarity, wetness and durability with Zaino and maintenance will be far easier.
Lexus Connoisseur
Lexus Connoisseur
It was Oyster Pearl. All carnaubas darken paint slightly but #26 has a slight yellowish tinge. Small but noticeable. This came to light after I switched to P21S.
acbrisker
03-29-07 04:05 PM
