Review of JEFFS Werkstatt.
That finish is beautiful on the IS300. What did you use before you used the Werkstatt to maintain your car. I just got some Klasse AIO and will be looking around for a good topping after I apply it. My car is parked outside most of the time so I may need to get something durable, perhaps a good carnuba wax.
Thanks, I've used most of the products out there on my car at one time or another. Previous to Werkstatt I was using M21 (NXT before that). I would still be using M21 but I was attracted to Werkstatt's potential ease of use. Klasse is made by Carlack, the same company that makes Werkstatt, so they will probably play well together. If you don't want to use Klasse SG then I suggest trying Werkstatt's AJ or AJT as a topper to AIO.
Dawn or any other dish soap will not remove Klasse or the Werkstatt. Just clean the car (you only need to clay the car if it has comtaminants on the surface....if you have clayed it in the last month or two it probably only needs to clayed in spots if at all but it certainly won't hurt anything) and apply the Prime and AJ. If your paint is still in great shape you can just wash it and apply the AJ over Klasse AIO without ANY problem.
