removing double sided tape from window visor??
10-01-06, 11:44 AM
i bought some used window visor and the wanted to replace the double sided tape. i tried heat gun and it gets most of it off but still leaves a layer or stickie.. i also used some "goof off" but its way too slow.. i need to make like 6 passes to clean a 1 inch area. takes too long. any easier way to remove the double side tape off the plastic window visor. ????
10-01-06, 06:51 PM
WD-40 and then wash with soap and water.
10-01-06, 11:58 PM
10-27-06, 10:29 AM
wd-40 didnt work that well (better then Goo-Off).. any other way? or will i just need to sit there and take my time and scrap it off with wd-40?
10-27-06, 01:11 PM
try zippo lighter fluid. Thats what i use to remove any sticky goo from tapes or stickers
10-29-06, 07:48 PM
not THAT desperate...yet...
02-24-13, 11:49 AM
How to get double sided tape off your vent visors
Use rubbing alcohol! It gets anything sticking off of just about any surface & doesn't hurt the surface material. It works!
02-24-13, 07:33 PM
Quote:
Originally Posted by
tiffiny70
I agree. Put some on a towel and it takes a little rubbing but it works
02-24-13, 07:41 PM
dont use a heat gun! your going to mess up the visors! that things weak plastic, will melt/deform easily
ahh, way to bump a 6 year old thread folks
02-27-13, 07:19 AM
Auto Detailing Master
tiffiny70
Rubbing alcohol can harm painted surfaces... just an FYI. If using on painted surfaces, it is best to dilute down to a 15% solution to be very safe.
03-04-13, 09:47 AM
use a heavy duty degreaser apply it with a tiny painters brush. worked great for me and didnt damage the plastic at all. if it does fade the plastic a bit, use rubbing compound to bring back the shine.
808_GS400
11-03-12 03:34 PM
Durrby
SC- 1st Gen (1992-2000)
03-16-10 09:06 PM
thomastan
Automotive Care & Detailing
08-24-08 10:34 AM
TripleDES
16
10-06-06 07:50 PM
chewbone
06-29-05 10:45 AM
car ,
double ,
installation ,
plastic ,
remove ,
removing ,
side ,
sided ,
stick ,
tape ,
vents ,
visor ,
visors ,
wind ,
window
