NOOOOOO!!! My paint looks old now. What should I do????
#31
Sort of on topic; when I bought my last car I wanted to a little experiment regarding polish frequency and it's effect on clear coats; the car was purchased with 16.1 mils of clear on it. It was used so the first thing I did was rather heavily compounded the car to remove the bulk of the scratches from the previous owner. I owned the car for just under 3 years and in that time I did that one major compounding, then 4 more light polishes (2x a year). When I sold the car it had an average of 16 mils of clear, so I had reduced it by one tenth of a mil. To put that in perspective you can normally remove ~1/3rd (on in this case 5 mils) of clear before you experience clear coat failure.
First off, the PC is not a very good buffer. It is great for waxing and mild polishing, but it would take forever to use one to do a significant full-car buffing. My detailer uses a large orbital buffer to remove scratches, then polishes with a PC.
If someone maintains their car properly from the start the PC is imo, the best $109 investment they can make towards the long term paint appearance and health of their car.
Best regards.
#32
I almost have the exact same car... X Package, Obsidian, Nav, but I got it with cashmere and 10/01/06 =P But I can understand how you feel
Anyway, I bought a 6" cordless random orbital from Home Depot (the name escapes me now), and it's my first one. At the beginning I was hesitant about using it on my new car, so I tried the trunk first to see if I knew how to handle and use it without damage. Well it turned out pretty good, so I went with the rest of the car. While it's not a PC, it did it's job. It had enough power and was effective for me. I kinda wish I bought a PC instead, but I have to say, it really beats doing everything by hand, and does a better job. I haven't used any really abrasive pads or compounds, and I don't know much about it, but this weekend I'm planning to try out my new wax after I use Dawn and clay the car.
I like to do things myself, and it's almost like a hobby now, so I'm ok with it. But like other said, you might consider taking it to a Pro first before going head-on now. My paint is still in pretty good condition, so It's no problem with just wax. I heard something about wet-sanding for things like this, but I don't know much about it. So maybe... find a pro first anyway
#33
Sort of on topic; when I bought my last car I wanted to a little experiment regarding polish frequency and it's effect on clear coats; the car was purchased with 16.1 mils of clear on it. When I sold the car it had an average of 16 mils of clear, so I had reduced it by one tenth of a mil. To put that in perspective you can normally remove ~1/3rd (on in this case 5 mils) of clear before you experience clear coat failure.
#34
Curious as to how you knew that you had 16.1 mils of clear coat. Did you use a mil guage to check the thickness of the paint? That is over 1 1/2 centimeters of clear paint. Very thick. I used to be aerospace finisher in my previous life and we always had to follow a mil spec thickness for all topcoats and primers. Average thickness of the topcoat finish (finish coat-glossy) was between 1.5-2.6 mils thick. This is for an airplane that will not need another coat of paint for 2-5 yrs. I am not bashing on you, just curious is all. It just seems like a lot of paint.
I use a Checkline dcfn 3000 PTG.
Thanks for the correction!
O. L. T.
SC- 1st Gen (1992-2000)
44
12-07-06 09:49 AM
