Maintaining clearbra on IS
I got my clearbra installed about a month ago. Now, I'm curious as to whether it has to be maintained in any way. I heard someone mentioned that it should be waxed. Is that required?
If so, can someone recommend some type wax that i can quickly apply after a car wash? I'm not looking into spending hours waxing the car, but would like to keep the clearbra in good shape with minimal effort on my IS.
Thanks for any tips.
The best product for a clear bra is Plexus - http://www.plexusplasticcleaner.com/plexus.html
Next best would be pure Carnuba Wax.
Koz
Koz
Koz
Koz
How often should I apply this product on the clearbra? Also, is that plexus thing safe for use on the non-clearbra portions of the car?
Plexus is fairly safe assuming you use it on your car when your car is clean w/ a clean microfiber cloth. Motorcycle riders commonly used Plexus. It is also good for Lexan which is notoriously easy to scratch. I use it on motorcycle helmet visors, windows, instrument gauge clusters, etc.. Good stuff.
I have a Llumar clear bra and my installer told me to treat it as you would treat any other part of the exterior - use the same wax, car wash, etc.
My clear bra is currently Zaino'd and it works fine.
Plexus works real well for most clear bras. I install them daily and found that though plexus works good, a quick detailer seems works a little better and can be used on the rest of the car. Meguiars final inspection or other quality product once a month or more keeps the film looking good. With the LLumar and Venture film you don't want to use a wax with dye in it like a lot of carnauba products. The film doesn't have a top coat and the wax will work its way in and stain the film.
There is always a chance for dirt to build up around the edges on clear bras. As long as the edges are sealed properly than it should clean up without any trouble. Using a damp lint free towel or quick detailer will remove the build up.
The cleaner you keep the clear bra the better it will look. This is very important on the films that don't have top coats like Venture and LLumar films.
It would be best to call and find what your local dealer is using. Seems like most use 3M which is a hard coat film. Clear Shield is hard coat and Venture recently released a hard coat film as well. The Venture is the smoothest out of them all so if you have a dark colored car than that is the one to look for.
Ahhadanny
Automotive Care & Detailing
31
07-29-17 11:27 PM
gassman
09-22-06 03:18 AM
