Wax won't come off.
When you draw your fingers over the paint does it feel smooth? Did you clay your paint before you waxed? Do these spots look like they are something sitting on the paint or pits in the paint that have collected wax? How old is the car? What color? Can you photograph the white spots? If this is dried wax in pits then you will need to clean your car with a paint cleaner or body solvent and then try using a wax that doesn't dry white like NXT Tech wax or Meguiar's #21 Synthetic Wax.
Well if they are little droplets like paint overspray you can clay them off. If they are pits you might be able to minimize them with a PC or rotary and an aggressive polish. I'd caution that if the pits are deep enough to hold wax they probably cannot be completely removed. If you use the body solvent like Dupont Prepsol you can get the old wax out and then I'd use a glaze like Meguiar's #7 and follow up with NXT Tech wax or #21. These product won't dry white and will not be as obvious.
SGT
Automotive Care & Detailing
11-06-05 03:29 PM
