Clay Kit vs. Paint Cleaner
Easy question for you guys, but I'm confused...
I just bought Meguiars Smooth Surface Clay Kit as well as the Deep Crystal Paint Cleaner and #7 Glaze. I already have tons of paste wax here.
Can I substitute the paint cleaner for the clay bar or are they two seperate processes? This "Paint Cleaner" claims to do the same thing, remove surface contamination.
The paint cleaner mainly removes tar and waterspots and light surface contamination, while the clay bar removes everything.
You can substitute the clay bar for the paint cleaner though.
Always start with clay. The clay will lift any contaminants in the paint. I've never used Deep Crystal, but any Paint cleaner is normally used to clean the paint and prepare it for LSP (last step product), aka wax.
Depending on what "look" you are looking for, you could use all products for added gloss. Clay, cleaner, glaze, then wax.
If you don't have the time, I'd get a sealant. Then clay, seal, wax (optional). The sealant is your layer of protection.
Good luck! Post some pics when you're done.
If its this cleaner
http://www.meguiars.com/?auto-paint-...-Paint-Cleaner
Ive used it and it works good. But i would still use they clay first, then use the cleaner. The clay will remove surface contaminates that will be stuborn with the cleaner, and then the cleaner will remove some stuff the clay wont. My paint was jacked up and the clay or polish wouldnt touch it, but the cleaner worked. ive also used the polish
http://www.meguiars.com/?car-polishe...-System-Polish
Its like a three step system of polishes and claners ending with a carnuba wax. I just used NXT paste wax instead.
Thats my two cents worth
They clay and cleaner are still separate products, each with value....I'd use both. The clay will remove surface contaminants, overspray, etc. The cleaner can go one step further and help with micromarring and maybe even fine swirls. (It's not a replacement for a polish, but if you don't want to go to that extent it's still a fine product.)
All the products you bought are great. Depending on the color of your vehicle, the glaze may not offer much to the eye. If it's a dark color, it (the glaze) will definitely help hide some swirls and imperfections. This is temporary though - don't expect much durability. You can top the glaze with a sealant or a wax. As mentioned above, a good sealant is great defense from surface contamination and swirls. On a light color with pearl - or any color with a lot of metallic - it'll also make the finish really pop. You can top with wax if you'd like for more wetness and reflection.
There is absolutely no way a paint cleaner can achieve what a clay bar can do.
With that being said, try this. Grab a ziploc bag, stick your hand in it and run it over your hood. It will feel like sandpaper. Do 1/2 with the clay bar and do the other with the paint cleaner. Run your hand in the ziploc bag over both sides.
I'll bet any amount of money the paint cleaner cannot achieve the results of a clay bar.
Steve
Steve
O. L. T.
Automotive Care & Detailing
12
09-08-05 02:40 PM
