Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
headlight restoration with 1500, 2000, PLastX
Old 09-08-10, 06:04 AM
  #166
Lexizm
Lexizm's Avatar
Originally Posted by WaldGS430
i need to try this.. otherwise i can pay a guy 50 to do it
I wouldn't pay anyone to do this, you can do it yourself. Plus your going to have to do this again depending on how long you keep the car.
Old 09-08-10, 11:57 AM
  #167
intermec
intermec's Avatar
Originally Posted by stevechumo
How long does it stay clean like that? I used the same product and the clarity only lasted for 1 month.
used other product but pretty much the same, after a month or so, it starts to get "yellow" again.
I didn't do the sanding though.
http://siennachat.com/forum/index.php/topic,2343.0.html
Old 09-08-10, 12:05 PM
  #168
MrG4Life
MrG4Life's Avatar
Use some of that 50 bucks towards the products and do it on your own.
Old 09-08-10, 08:09 PM
  #169
Andy Guy
Andy Guy's Avatar
It works pretty well if you have patients, I just did that today on my GS. I noticed a bigger difference if you use a Foam app instead of the microfiber app. Foam app seemed like it worked into the light more and it polished out the yellow. Its not suppose to protect it, I threw some wax on there to protect for a bit, but you just have to repolish with the Plastx the next time you wash the car.
Old 09-09-10, 02:33 PM
  #170
stevechumo
stevechumo's Avatar
Keep polishing it isn't a good solution, because the plastic housing will be slowly removed and there'll be no more plastic left. Polishing compound actually removes the material.
Old 09-09-10, 04:46 PM
  #171
LiCelsior
Retired
LiCelsior's Avatar
plastx wont remove that much, wetsanding is prob something u want to not do so much.
Old 09-11-10, 08:54 AM
  #172
Tipler
Tipler's Avatar
used Plastx and it didn't do anything ,what next the Mequair 's kit or 3m polishing ?
Old 11-15-10, 01:21 PM
  #173
GS3MGS
GS3MGS's Avatar
Default what did i do wrong ... Help
I just got done with sanding w/2000 grit paper and headlight was very dull and hazy. I then applied plasti x and it got slightly better but not 100% so i used wax to see if that would help but very little difference. My head lights still look dull . I didn't use a orbital buffer is that what iam missing or did i just mess up my headlights.. I need some advice before i go out and buy a buffer. Thanks
Old 11-15-10, 01:56 PM
  #174
jfelbab
jfelbab's Avatar
You could try this kit. It works with a drill so it is better than trying to polish out the haze by hand.
That said, I'll be the first to recommend a good dual action buffer. I purchased my PC in March, 1995 and it has been the best tool for automotive detailing I've ever owned. After 15 years of heavy use it still works like new.
Old 11-15-10, 05:47 PM
  #175
GS3MGS
GS3MGS's Avatar
Default Finally Clear....
So for those of you stuck in the foggy hazy stage after sanding and cant figure out how to get rid of the cloudy dingy look. I was stuck in this stage my self until i went to Auto Zone and bought an inexpensive orbital buffer for $24.99 and after about 5min of buffing with plastix i finally started to see nice clear lenses. I had thought i messed up my headlights and had to buy new ones, but after some hard work and not giving up it payed off. I would had never done it with out the buffer for those of you trying to polish by hand as i was doing.
Old 11-20-10, 11:48 AM
  #176
1uzDreamSC
1uzDreamSC's Avatar
awesome job
Old 12-07-10, 11:41 AM
  #177
exvelocity
exvelocity's Avatar
Usually it looks OK for few weeks and starts yellowing again ,no matter what wax you or polish you use . This is only a temporary fix.
All polycarbonate lenses are clearcoated from the factory and if the clearcoat is not there, the plastic will deteriorate . This is why I don't even waste time with polishing, I sand the lenses down and apply automotive grade clearcoat with UV block,
Old 12-07-10, 02:02 PM
  #178
Jewcano
No Sir, I Don't Like It
Jewcano's Avatar
^How much would you charge to do the latter half?
Old 12-08-10, 05:39 AM
  #179
exvelocity
exvelocity's Avatar
***,as long as it's the outside of the lenses
Old 12-08-10, 04:44 PM
  #180
Jewcano
Jewcano's Avatar
Originally Posted by exvelocity
125,as long as it's the outside of the lenses
Blyad.....ti daragoy.....nyet spacebo .
Quick Reply: headlight restoration with 1500, 2000, PLastX
