headlight restoration with 1500, 2000, PLastX
#196
Needs what? 1500>2000>PlastX ?
I would think twice about putting sandpaper on the headlights of a car that new. You will probably do more harm then good and easily sand off the UV coating with that sandpaper. What makes you think you need it?
Sanding down usually is needed on older cars that already have alot of deeper scratches or have the coating coming off from sun damage.
#197
+1 An orbital buffer would've cleaned up the light a little bit more. I tried the Mothers Powerball Restoration Kit on my Civic, and it turned out very well. The only bad thing is I have to re-do them or reapply the polish every couple months or else they will start hazing again. I tried using a sealer and wax on them, but they still glazed over.
Only way to permanently protect them is to put a permanent UV coating that hardens like a clear-coat.
#198
sorry if theres a logical explenation for this and im just jumping to conclusions. i also didnt read the whole thread so idk if there is some explenation to it, but just glasning at the pics those are my thoughts and opinoins. i wouldnt want me or anyone else to be fooled by before and after pics that look that good. and then be frustrated when we can't get similar results. lol
#199
I got a used set of lights which i retrofitted some rx330 projectors in...
I've done the 1500,2000,plastx procedure on my old es300, and my original rsx headlamps which turned out perfect. However for this particular set, I've still got some haziness after polishing. The interior side of the lens is fine since I just assembled them - could this not be a surface oxidation problem![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Any examples of buffer burn?
#200
im a painter at a body shop in az. i fix head lights like this all the time since they get so bad from the sun out here. i know the method described does work well, but will need to be repeated every few months since the sun will just keep damaging them. i found the best way to keep them looking good is to sand em down with 800 to 1200 grit wetsand paper and clear them with a clear coat like you would use on the top coat of a paint job. it will protect from the sun and keep em looking good. i know not everyone has the tools or materials for this kind of process but its what ive found to work best.
#202
The aircraft world uses this stuff on plastic windshields... http://www.aircraftspruce.com/catalo...cromeshstd.php
(basically expensive sandpaper)
#204
Another alternative to keep the lights from going bad again is to use clear headlight tints. I bought a set of precut headlight tint from Ebay and put it over the lights. The tint is so thick that makes me think it'll last a life time. The clear tint can also be called headlight cover, clear bra..etc.
#207
Guy your going to laugh but I heard what i thought was a old wife tale...
Have you tried toothpaste.
I used a small amount of tooth paste on a slightly damp piece of tissue and rub the lens although my lens was fade and not scratched it brought it back to new.
My friend and I look in amazement we really thought it would not work,,
Going give your lens a try...
#208
the restoration isn't necessary if you are going to use the clear coat. you just sand the lenses like i described before, mask off the lenses or take them out of the car, and then clear them. This will solve the wear and tear problem. I did this to my is350 a year ago and they still look perfect. I've also cleared several sets of lights 4 years ago that i still see to this day driving around that look perfect. No sign of oxidizing again at all.
#209
Limited success with the 3M kit with a drill, just like the OP they look better but there is still slight haziness and i really want that crystal flawless clear look
