headlight restoration with 1500, 2000, PLastX
#91
I've used Blue Magic in the past and it works okay but I got much better results with the Meguiar's Plastix that I squirted on the headlamp then worked in a bit with my fingers then (here's the kicker) I used my old Sears Random orbital ($25) buffer with a terry bonnet. Then finished with a Pak Shak blue microfiber towel. It looks GREAT!
#92
I forgot to mention I used a rotary with a cutting pad. I used the blue magic with a rotary. The blue magic is for the deeper scratches and the Plastx for the finer scratches and haze
It's just more abrasive than Plastx. I can do one side of the headlight in under a minute for just polishing
#93
so i did this to my 00 gs300 last week and it turned out great! but i feel like there should be a "last step" after plastX, like some kind of uv protection or polish? but anyways thanks for the pics / guide
i swear by this stuff now...cheap / easy / takes a lot of time but well worth it!
#96
I love you guys.
I rinsed them off, wiped them down, applied the PlastX with an applicator pad, and wiped off the residue with a microfiber towel. Here are the results:
Before:
![Name: IMAGE_085.jpg
Size: 26.5 KB](https://www.clublexus.com/forums/attachments/automotive-care-and-detailing/454247d1501791993-headlight-restoration-with-1500-2000-plastx-image_085.jpg)
![Name: IMAGE_086.jpg
Size: 22.4 KB](https://www.clublexus.com/forums/attachments/automotive-care-and-detailing/454248d1501791993-headlight-restoration-with-1500-2000-plastx-image_086.jpg)
After:
![Name: IMAGE_090.jpg
Size: 33.7 KB](https://www.clublexus.com/forums/attachments/automotive-care-and-detailing/454249d1501791993-headlight-restoration-with-1500-2000-plastx-image_090.jpg)
![Name: IMAGE_089.jpg
Size: 29.2 KB](https://www.clublexus.com/forums/attachments/automotive-care-and-detailing/454250d1501791993-headlight-restoration-with-1500-2000-plastx-image_089.jpg)
Before:
After:
![](https://img.photobucket.com/albums/v258/Jeembo/IMAGE_088.jpg)
#99
iModerate
#101
iModerate
Move up to 2500 or 3000 grit paper and then have them machine polished. That should get them where you want them. Post pics if you have them.
#103
iModerate
#104
600 is WAY too rough
more questions I have
1-Does this procedure works with the stop lights as well (There is no reason why it should not)
2-Does this procedure work with glass head light cover (not plastic)
Many thanks for the answerers in advance.
