OK to Use Brush ?
OK to use brush ?
Is it safe to wash with brush - the type from WalMart, with plastic hair but fine feathered ends ?
like this :
![](http://www.mclendons.com/img/products/10/10881180.jpg)
I'm a lazy bastard and wash my car only occasionaly so it get dirty and it seems using the brush first, rinse off, then use mitt is the most effective way of cleaning. comments ?
thanks
like this :
thanks
Oof, kidney punch, I'm in pain. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Don't do it. Those things do nothing but introduce swirl marks. If you'd like an easy first step, go for a foam gun instead. They're great at lifting dirt. Use a quality shampoo, a good sheepskin or microfiber mitt, and you'll be amazed at how easy it is to wash your car.
I have used a similar brush for years to get rid of the bugs. No swirl marks. Brush is actually better than microfibre or cotton towel at washing, since it does not push particles against the paint surface.
The trick is to use it ONLY when the car surface is cold. Use ONLY cold water to wash your car.
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
so it scares me to go at it first with a mitt/sponge
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
My pro detailer tried a high end wash brush (seems to me it was boars hair or something supposedly super soft) on my GS and it left micro-fine scratches in the paint. Probably would be OK on lighter colors but I asked never to use it on my black onyx cars again.
i'd use one of those microfiber mits works really good even for black cars. The brush is good too, I have one of those just as long as it never never touches the ground or anything but the car it's ok. Just don't put too much pressure on it or you will wind up with scratches. Wax every other wash and scratches will be reduced to a minimum
OK to use brush ?
like this :
thanks
like this :
thanks
