Remove wax from plastic molding?
I generally don't use a clay bar on plastic trim or molding. A small nylon detailing brush will do the trick. You can lubricate it with QD spray or a mild car wash shampoo solution. There's a product called Wax Blaster - comes in a small bottle with a built-in foam applicator - that's awesome for this purpose too. Very gentle and easy to use.
Obviously prevention is easier than cleanup. 3M blue painter's tape is perfect for this role - apply it to the plastic prior to waxing and you'll save some time and bother.
Both the texture and the dye removed from the trim...not a pretty sight, and not easily covered up. Great to hear that it works for you. I'm always paranoid about household items like that, particularly when there are so many automotive-specific products and techniques that work so well.
I have also heard people use peanut butter to remove the wax. They say that the peanut oil removes it.
I was wondering if anyone else has heard of this?
Anyways...thanks for the info!!!
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Supposedly that's true. But I've never confirmed it....again, why? Then you have to remove the peanut oil? ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Unless the wax is really old or in a horribly difficult to reach place, it's contact/abrasion that will remove it, not any chemical or secret recipe. The Pep Boys $2.99 detailing brush will last forever and QD spray or even water will likely suffice as a lubricant.
Personally, I hate Simple Green.
It's one of those general purpose cleaners that does nothing really well. In automotive use, it's best known for leaving an oily residue that's difficult to remove. By all means, if it works for you, that's great. I'd just recommend using as little as possible, and at least considering Wax Blaster or some of the other methods offered above.
