PC 7424 or Ultimate Detailing Machine?
Ok, so I think I'm going to order a polisher and have come across the Porter Cable and a new machine called the Ultimate Detailing Machine.
Any thoughts on these two. PC is the tried and true, but the UDM claims to be an improvement?
Also question on pads. How do you clean them and how long do they last?
Thanks guys!
Thanks guys!
I've heard great things about the UDM, but have never tried one. I can't say which route I'd go if I were in the market today, but I'd definitely read reviews and check out the dedicated detailing forum sites for information. www.autopia.org, www.autogeek.net, and www.detailcity.com are three of my favorites.
I clean pads with car wash shampoo & water. I generally let them soak for a bit, followed by scrubbing with a dedicated nylon brush. I rinse them thoroughly and let them air dry in a well ventilated area. Foam pads are really durable and should last a long time. I generally notice separation from the backing before any serious degradation to the foam. LC orange pads are my most-used ones, and I last bought in February. I cycle a set of three and I'd estimate they easily have another 9-12 months of life in them. Or in more quantifiable terms, I usually get two dozen uses per pad and I know many detailers who extract more than that.
Good luck - have a blast with whichever machine you buy...
Next week, I'm going to post a picture of the PC vs UDM.
I'm hearing it is not quite as powerful as a rotary but more than a PC.
Thanks for the feedback. Looks like the UDM is the way to go. I looked at Autogeek and it seems that a kit with a few pads seems like the best value along with the free XT Carnuba wax.
It will be a big change from my 20 yr old Sears Craftsman 10" random orbital which is pretty much only good for wax. Stopped using actually, that pad is too big.
I have one and like it, but have never used a PC for comparison.
Has anyone had the chance to compare? Seems like a great solution for those of us too timid to venture into rotary waters, but with a need for horsepower on badly damaged vehicles...
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
I was there with Blkexcoupe when we did the. UDM vs rotary.
No doubt the UDM is quicker than the PC, but that's all there is to it. It just gets the job done quicker. In the end, the rotary was needed to remove the deeper defects.
I wouldn't think of using the UDM on a heavily oxidized paint though.
Is it worth the extra $30 for the UDM over the PC? Yes, if you do not have a PC yet. If you already have a PC and want better/quicker results, jump for the rotary. Yes, you have to learn how to use one, but once you get it down correctly, you'll never want to pick up another random orbit buffer for defect removal.
Just practice using the rotary on some sort of junk'd hood or something. Believe me, you will not regret it once you go rotary. As long as you follow the basics, you'll be fine!
I'd say the UDM is 50% faster than the PC in swirled paints.
if you're reluctant to use a rotary, then yes, go for the UDM
Oh yea. One thing I noticed was that the vibration for the UDM max speed was about the same as the PC at max speed. That's not bad considering the UDM's max speed is a tad whee faster.
When Blkexcoupe jumped to the rotary, the first thing he noticed (other than the fact that I was yelling at him to keep the pad flat), was that the rotary had no vibration
I
Thanks for the great feedback! At some point I probably will pull the trigger on a rotary but I just haven't justified the expense or learning curve. Most of the vehicles are I touch are in decent enough shape, but it would definitely be nice on occasion to speed things up a bit.
50% is quite an improvement though, especially when you know you'll be spending a fair chunk of time with the PC.
