aerospace protectant 303 on my dash?
Can you tell me how to use it, it was not cheap. Where should I put it, I have put it on my scuff plates and seem to make cleaning easier?
Is it like a armor all with SPF?
I have cashmere interior so it's hard to keep anything clean, plastic, leather etc.
it's better than armor all.
Just mist your dash. You dont need a whole lot. Just use enough that when you wipe, you're able to cover the area. My dash only needs 3 sprays. Left, Center, and Right.
Then one spray to the center console and wipe it all down with a microfiber towel. I use two sprays per door panel. Basically just dont soak any one part in 303 and you're good to go.
I love using 303, doesnt leave a lot of shine, more like the oem feel. I have accidentally put it on the wood trim and it was fine. I prefer to put a light coat of wax on the wood trim, seems to turn out better
Heres a tip. Take a microfiber towel, dip in water, wring out excess water. Apply several spritzes to MF, and wipe on desired location. You will find a much more even application, and results will be simply stunning. 303 is an excellent product!
RJMacReady (07-07-23)
Never used this product. But I've had excellent luck with PLEXUS, another aviation product originally developed for plastic canopies and windshields. I use it on all plastic parts, including the window tint. Imparts a very smooth finish with absolutely no residue or slickness. It fills in micro scratches on plastic, making them far less visible. If you feel the surface after treatment you can definitely feel the smoothness. Any motorcycle store stocks it. It's a staple in that industry.
http://www.plexusplasticcleaner.com/frames.html
I finally picked up a bottle of 303 and was finally able to give it a try today.
I am very impressed with the product. The shine was a little more than expected but it really looked good on the black interior of the ES.
